    [Tutorial > Modeling] Grooves in a tube?
    24 Posts 10 Posters 9.9k Views 10 Watching
    • GaieusG
      Now Pedro that would realy be better just to texture a somple tube. But of course modelling it would be even more of a challenge!
      • E
        ELYSIUM
        Tks Gaieus,
        I know, i have been thinking if it is really worth it, it might give too much weight to the model, for a barely visible feature, but in either case even if ultimately i don't use it, it will still be useful to learn some more sketchup skills.
        • boofredlayB
          boofredlay
          Here is the tutorial I promised. I hope this helps. Just click the image.
          http://www.sketchucation.com/forums/scf/sas/Tutorials/Rifle2.jpg
          Elysium, I agree with Gai, just texture a tube with a rope image.
          I don't know if there is a follow me twisting ruby out there, this might prove helpful if so.
            alpro
            Thanks Eric, your tuts are always very helpful and appreciated.
            Mike
            • E
              ELYSIUM
              Tks Eric, i already knew this technique, and used it to make spiral columns.
              I had hope that you knew a way to make it kind of follow me, so that it could make the same effect on curved sections.
              Tks again.
              ( a ruby to do this whould be very usefull )
              • soloS
                Eric
                I found another use for it....
                http://img526.imageshack.us/img526/3474/007ik2.gif
                • boofredlayB
                  boofredlay
                  Is that Gai on the other end? Ok, now I see 007. 😉
                    3eighty
                    Thanks again for your time and help eric///Pretty cool solo.. 😄
                    • boofredlayB
                      boofredlay
                      Glad to help. Your welcome. 🤓
                      • GaieusG
                        I couldn't agree more. Even if a technique/trick is not used ultimately, one always wishes to knowhow it could be done (though we were cast out of the Paradise for this urge to knowthings... 😒 )
                        Eric: perfect as usual... 😄
                        Solo: really cool. And yes, Eric, that's me! 😄
                        • EdsonE
                          Edson
                          eric,
                          very nice tut. it reminded me of the way ancient builders used to cut stone to make twisted columns. the process must have been the same.
                          http://www.mahfuz.arq.br
                            Roger
                            A threaded tube is an interesting special case. I did a model a thousand threaded holes. SU just did not want to deal with all the geometry even though it was a component. Moves take too much math. I just painted the inside of the whole with a set of parallel lines. In that configuration it is hard to discriminate if the lines are spiral or concentric. You might also try creating an angled jpeg pattern and painting the repeating pattern on the inside of a tube. The reason this would work well is that the inside of a tube can only be seen from a very narrow angle, so the fact that the pattern is flat would not be apparent in the final work. Animation would not work, but for a static view I think it would save a lot of useless geometry.
                            http://www.azcreative.com
                            • Jean LemireJ
                              Jean Lemire
                              Hi folks.
                              Look in Wikipedia for information about riffles. You will see smooth bore, polygonal bore (Boofredlay's tutorial) and riffled bore (see attached SU file).
                              The file is a bit large, sorry.
                              Riffled bore.zip
                                dylan
                                Thanks Jean, that really is a good way of achieving that effect.
                                http://dmdarchitecture.co.uk/
                                • boofredlayB
                                  boofredlay
                                  Jean, that last scene scared me 😮 😄
                                    3eighty
                                    Jean and everbody else..Thanks for your time and work..Lots of good info..
                                    • boofredlayB
                                      boofredlay
                                      Your welcome, and I think we had more fun than you did. 😄
                                      • Jean LemireJ
                                        Jean Lemire
                                        Hi folks.
                                        Of course it is fun, otherwise, I would not be doing these tutorials.
