    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    [Tutorial > Modeling] Grooves in a tube?
    24 Posts 10 Posters 8.2k Views 10 Watching
    • 3 Offline
      3eighty
      Any ideas on how to place a groove on the inside of a tube...Such as in a gun barrel...Can the follow-me-tool be made to make a negative groove?..Just a thought..
      Thank You
      • boofredlayB Offline
        boofredlay
        The follow me tool will cut the length of a tube but if you want it to twist (rifle) then you have to do some more work.
        Is this what you mean?
        http://www.sketchucation.com/forums/scf/sas/Tutorials/Rifle.jpg
        • 3 Offline
          3eighty
          Yes, Thats it...Not as many grooves (perhaps 2-3) and of course the tube end would have to be round...Thanks for taking the time to answer and start me off..Think of the opening shot in the James Bond movies...
          Richard
            boofredlay
            That is exactly what I thought when I panned around to this view 😄
            If you need me to make a quick tut just ask. It's really simple.
            • 3 Offline
              3eighty
              When you have time, A tut would be nice and much appreciated...I just can't seem to hit the right thoughts..
              Thanks for your time and efforts..
              • E Offline
                ELYSIUM
                Hi all,
                Eric i too could use some help, i need to model a towing wire for my tank model, wich has the same groves, but on the outside, process is shurely the same, i just have to delete the outer geometry after no?
                Here is a pic of what i need.
                tks for your help!
                  Now Pedro that would realy be better just to texture a somple tube. But of course modelling it would be even more of a challenge!
                  • E Offline
                    ELYSIUM
                    Tks Gaieus,
                    I know, i have been thinking if it is really worth it, it might give too much weight to the model, for a barely visible feature, but in either case even if ultimately i don't use it, it will still be useful to learn some more sketchup skills.
                      boofredlay
                      Here is the tutorial I promised. I hope this helps. Just click the image.
                      http://www.sketchucation.com/forums/scf/sas/Tutorials/Rifle2.jpg
                      Elysium, I agree with Gai, just texture a tube with a rope image.
                      I don't know if there is a follow me twisting ruby out there, this might prove helpful if so.
                        alpro
                        Thanks Eric, your tuts are always very helpful and appreciated.
                        Mike
                        • E Offline
                          ELYSIUM
                          Tks Eric, i already knew this technique, and used it to make spiral columns.
                          I had hope that you knew a way to make it kind of follow me, so that it could make the same effect on curved sections.
                          Tks again.
                          ( a ruby to do this whould be very usefull )
                          • soloS Offline
                            Eric
                            I found another use for it....
                            http://img526.imageshack.us/img526/3474/007ik2.gif
                              boofredlay
                              Is that Gai on the other end? Ok, now I see 007. 😉
                              • 3 Offline
                                3eighty
                                Thanks again for your time and help eric///Pretty cool solo.. 😄
                                  boofredlay
                                  Glad to help. Your welcome. 🤓
                                    I couldn't agree more. Even if a technique/trick is not used ultimately, one always wishes to knowhow it could be done (though we were cast out of the Paradise for this urge to knowthings... 😒 )
                                    Eric: perfect as usual... 😄
                                    Solo: really cool. And yes, Eric, that's me! 😄
                                    • EdsonE Offline
                                      Edson
                                      eric,
                                      very nice tut. it reminded me of the way ancient builders used to cut stone to make twisted columns. the process must have been the same.
                                      http://www.mahfuz.arq.br
                                        Roger
                                        A threaded tube is an interesting special case. I did a model a thousand threaded holes. SU just did not want to deal with all the geometry even though it was a component. Moves take too much math. I just painted the inside of the whole with a set of parallel lines. In that configuration it is hard to discriminate if the lines are spiral or concentric. You might also try creating an angled jpeg pattern and painting the repeating pattern on the inside of a tube. The reason this would work well is that the inside of a tube can only be seen from a very narrow angle, so the fact that the pattern is flat would not be apparent in the final work. Animation would not work, but for a static view I think it would save a lot of useless geometry.
                                        http://www.azcreative.com
                                        • Jean LemireJ Offline
                                          Jean Lemire
                                          Hi folks.
                                          Look in Wikipedia for information about riffles. You will see smooth bore, polygonal bore (Boofredlay's tutorial) and riffled bore (see attached SU file).
                                          The file is a bit large, sorry.
                                          Riffled bore.zip
                                            dylan
                                            Thanks Jean, that really is a good way of achieving that effect.
                                            http://dmdarchitecture.co.uk/
