    UI.openURL(executable + params)
    17 Posts 6 Posters 4.6k Views 6 Watching
    • W
      Whaat
      'Dos' window is visible in the background so it is not clean solution.
      I think if you use the command "start" before the name of the executable, the dos window will disappear after executing the batch file.
      start kerkythea.exe script.kst
      Whaat
      • T
        tomasz
        Thanks Azuby,
        Don't worry. I am not familiar with MACs at all. You are simply at the much higher level of programming then me, so most of what you are writing sounds like a Chinese to me 😄 I simply would like to start Kerkythea on MAC with start.kst file as a parameter (file to be opened when KT starts).
        By the way, next version of KT is expected in few months and it will be available for MAC!
        It is what Giannis says.
        Thanks Whaat,
        I have done some investigation and the line in the batch file should look like:
        start "" "C:\Program Files\Kerkythea\Kerkythea.exe" "start.kst"
        Now it works (PC only 😞 )!
        Tomasz
        • T
          tomasz
          Azuby, I have finally understood what you have written in you first post (I am not very familiar with standard Ruby methods). It works excellent with "dir", but for some reason KT is being opened only when I close SU otherwise SU is hanging and KT awaiting to start (edit - it takes about 40sec KT to start).
          system("Kerkythea.exe start.kst")
          s=`Kerkythea.exe start.kst`
          works fine. Is it possible to run KT as a separate thread,
          so SU would be still working?
          Tomasz
          • T
            tomasz
            s=`c;/Program Files/Kerkythea/Kerkythea.exe "c;\\Program Files\\Kerkythea\\start.kst"`
            It is script that will run exe with parameter in "" (PC).
            For MAC I presume I will have to replace all \ by /.
            Still don't know how to keep SU alive when KT is running.
            Tomasz
              azuby
              Moin,
              you can't do this with Ruby threads, they let Sketchup freeze while your other application is running. The code would be
              Thread.new do `WHATEVER` end
              Also you can't use exec or fork. The only way would be writing a really simple server application, running it on localhost and call it from Sketchup.
              azuby
              *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
              Bad English? PM me, correct me. :smile:**
                Any ideas what's causing this glitch ?
                help=Sketchup.find_support_file("RoofHelp.mht","Plugins/")
                #=big file, but works...
                help=Sketchup.find_support_file("RoofHelp.pdf","Plugins/")
                #=small file, but not working ???
                UI.messagebox("ERROR\nRoof Help File NOT found.") if not UI.openURL("file:///"+help)
                On a PC with Vista UI.openURL will open almost any type of file except a PDF ?
                This is delaying my beta issue of Roof.rb as it needs a help file !
                • T
                  tomasz
                  The file name is case sensitive. Does it matter?
                  Try dir with the folder and look for the file.upcase.
                  Tomasz
                    I don't think it's the case or another thought I had was even blank-spaces in paths (tried gsub 20% etc without any change in results).
                    It just seems to dislike PDF files - other types - mht, htm, doc, txt et al work OK...
                    Is it a setting in Vista ?
                    • T
                      tomasz
                      I have no idea. I am working on XP.
                        Thanks anyway.
                        Just upgraded to a new PC - Core 2 Quad with 2Gb RAM - but it runs Vista...
                        Vista seems to be the problem...
