    Can't select individual surfaces created with push too.
    6 Posts 4 Posters 1.2k Views 4 Watching
    • N
      not registered yet
      I created a room volume by first laying out the floor plan in top view and then push up the layout to create the ceiling and walls. Now I can not select the floors, walls, etc individually to add unique fill to each. How can this be corrected?
      P: jimf233
      • EdsonE
        Edson
        could they be grouped? try clicking twice on the whole thing.
        http://www.mahfuz.arq.br
          Masta Squidge
          Either they are grouped as he said or you smoothed the corners. Smoothing the corners would make the whole object be one solid face.
          • N
            not registered yet
            thanks, they were grouped. Now another issue I am having is how to scale components from the library. Can there dimensions be changed?
            P: jimf233
              Masta Squidge
              just use the "scale" tool and it will show up with a bunch of litle boxes on a frame around it.
              grab one of the corners and drag it to increase or decrease the size.
              • Jean LemireJ
                Jean Lemire
                Hi folks.
                Te resize components like doors and windows, for example, you may need to use the Move Tool to avoid changing the frame size while changing the door or window size.
                Just ideas.
