    Circles and round lathed objects
    24 Posts 5 Posters 3.6k Views 5 Watching
    • N Offline
      not registered yet
      Oh, I just noticed Boofred's post. That's probably good, because I tried following the tutorial, but there's a step missing. I have the separated plane for follow-me to use, and I had all the edges selected, but I don't know what to click follow-me on to make it work. Also, the edges seem to de-select when I hit the follow-me tool.
      I'll check out the new tutorial now.
      P: AcousticGarden
      • N Offline
        not registered yet
        Wow Eric! Your end result was the coolest architectural gutter system ever! πŸ˜†
        Now, my turn to try...
        P: AcousticGarden
          You select the face of that small profile with the follow me tool.
          Don't bother with the edges deselecting - they do this all the time! πŸ˜„
            That's nice, Eric - and also highlights the drawbacks of the follow me tool with very sharp angles.
            • boofredlayB Offline
              boofredlay
              I went ahead and added this tut to the Tutorials & How-To / Modeling Forum.
              • N Offline
                not registered yet
                Worked like a charm. The selected face was visually de-selected upon choosing the follow-me tool, but it worked when I clicked the plane I wanted to border the top plane with.
                P: AcousticGarden
                  boofredlay
                  Yea, like Gai said, the surface or edges seem to be deslected when you grab the Follow Me tool.
                  Glad you got it to work for you.
                  • N Offline
                    not registered yet
                    Oh, I just realized another thing I'm curious about: Can you grab an object, and move it without distorting it? Like say you were doing an interior furniture layout. Could you move a complete piece of furniture in tact without the program trying to distort the object? I haven't seen a way to do that yet.
                    P: AcousticGarden
                      boofredlay
                      You have to make sure the "furniture" or whatever it is you want to move is separated from the rest of the model. To do this you make a group or component.
                      Check out the SU 5 tutorials on the SketchUp site. #22 will talk about components but check them all out. This is how I learnt. πŸ˜„
                      http://sketchup.google.com/gsu5vtvideos.html
                      Then check out the SU 6 Tutorails:
                      http://sketchup.google.com/gsu6vtvideos.html
                      • N Offline
                        not registered yet
                        Thanks. I think I've seen all the Sketch Up 6 tutorials.
                        I didn't bother with all the SU5 ones believing that the changes in 6 might make those obsolete. I'll check out the one you recommended as soon as I can.
                        So much to learn! πŸ˜„
                        P: AcousticGarden
                          ...I didn't bother with all the SU5 ones believing that the changes in 6 might make those obsolete...
                          Never think they are - most of the "basic" techniques are the same.
                          Also, there is a lot of things to update among the tuts - as well as the SU Guide which I also warmly recommend to go through...
                          • N Offline
                            not registered yet
                            The guide being the pdf book? I think I'm a little less than half way through that.
                            P: AcousticGarden
                              Well, it has a pdf version, too (I have never printed it nor I have a printer actually) so I guess it is.
                              A great resource.
                                Bert
                                GaΓ―eus wrote
                                In the tutorial, as you can see, the view is almost horizontal; that's how SU "tries" to assume on which plane you are trying to draw. So when you are looking "down", it will draw on the red/green plane, if you are looking rather from the "side" (with the horizon more or less in the middle), it will try to draw on the red/blue or green/blue plane (depending on which direction you are looking).
                                This is sometimes harder to do than what you did.
                                One more time I have learned something reading this forum,
                                Tank you all
                                Salutations (Best regards) Bert
                                  Bert, that's what we are all here for; learning and sharing...
                                  I have learnt a lot from this or the "old" and even the "Freee GGroups" forums...
