    Circles and round lathed objects
    24 Posts 5 Posters 3.4k Views 5 Watching
      mike d
      AcousticGarden
      is this what you are trying to acomplish
      RoundedCorner2.skp
      The grass is always GREENER on the roof.
        AG,
        your first method (creating a face to draw on) was quite intuitive - I do the same all the time. In the tutorial, as you can see, the view is almost horizontal; that's how SU "tries" to assume on which plane you are trying to draw. So when you are looking "down", it will draw on the red/green plane, if you are looking rather from the "side" (with the horizon more or less in the middle), it will try to draw on the red/blue or green/blue plane (depending on which direction you are looking).
        This is sometimes harder to do than what you did.
        RoundedCorner_tut.skp
        As for the rounded corner stuff, see a "Tutorial" below (go through the scenes)
          Hehe, Mike - just "cross posting..."
          πŸ˜„
            mike d
            that ok gai as long as we get his questions answered
            • N Offline
              not registered yet
              Quickly...thanks for the replies. Yes, Mike, I did look at your drawing, and that was one of the things I was trying to do.
              The other was turning a square corner with the follow-me tool. If you looked at my successful rounded corner rendition it was on the side of a box. I had wanted to go around the outside of the top horizontal plane of the box. Follow-me wouldn't take that order, but hit the corner and continued down vertically. I just have to adjust my mindset to make it right.
              Now I'll go have a look at the tutorial. πŸ˜„
              P: AcousticGarden
              • boofredlayB Offline
                boofredlay
                AG, I created another tut for the follow me. If you are going around the perimeter of a surface, no need to select all the lines, just the surface.
                Check it out.
                FollowMeTut.skp
                • N Offline
                  not registered yet
                  Oh, I just noticed Boofred's post. That's probably good, because I tried following the tutorial, but there's a step missing. I have the separated plane for follow-me to use, and I had all the edges selected, but I don't know what to click follow-me on to make it work. Also, the edges seem to de-select when I hit the follow-me tool.
                  I'll check out the new tutorial now.
                  P: AcousticGarden
                  • N Offline
                    not registered yet
                    Wow Eric! Your end result was the coolest architectural gutter system ever! πŸ˜†
                    Now, my turn to try...
                    P: AcousticGarden
                      You select the face of that small profile with the follow me tool.
                      Don't bother with the edges deselecting - they do this all the time! πŸ˜„
                        That's nice, Eric - and also highlights the drawbacks of the follow me tool with very sharp angles.
                          boofredlay
                          I went ahead and added this tut to the Tutorials & How-To / Modeling Forum.
                          • N Offline
                            not registered yet
                            Worked like a charm. The selected face was visually de-selected upon choosing the follow-me tool, but it worked when I clicked the plane I wanted to border the top plane with.
                            P: AcousticGarden
                              boofredlay
                              Yea, like Gai said, the surface or edges seem to be deslected when you grab the Follow Me tool.
                              Glad you got it to work for you.
                              • N Offline
                                not registered yet
                                Oh, I just realized another thing I'm curious about: Can you grab an object, and move it without distorting it? Like say you were doing an interior furniture layout. Could you move a complete piece of furniture in tact without the program trying to distort the object? I haven't seen a way to do that yet.
                                P: AcousticGarden
                                  boofredlay
                                  You have to make sure the "furniture" or whatever it is you want to move is separated from the rest of the model. To do this you make a group or component.
                                  Check out the SU 5 tutorials on the SketchUp site. #22 will talk about components but check them all out. This is how I learnt. πŸ˜„
                                  http://sketchup.google.com/gsu5vtvideos.html
                                  Then check out the SU 6 Tutorails:
                                  http://sketchup.google.com/gsu6vtvideos.html
                                  • N Offline
                                    not registered yet
                                    Thanks. I think I've seen all the Sketch Up 6 tutorials.
                                    I didn't bother with all the SU5 ones believing that the changes in 6 might make those obsolete. I'll check out the one you recommended as soon as I can.
                                    So much to learn! πŸ˜„
                                    P: AcousticGarden
                                      ...I didn't bother with all the SU5 ones believing that the changes in 6 might make those obsolete...
                                      Never think they are - most of the "basic" techniques are the same.
                                      Also, there is a lot of things to update among the tuts - as well as the SU Guide which I also warmly recommend to go through...
                                      • N Offline
                                        not registered yet
                                        The guide being the pdf book? I think I'm a little less than half way through that.
                                        P: AcousticGarden
                                          Well, it has a pdf version, too (I have never printed it nor I have a printer actually) so I guess it is.
                                          A great resource.
                                            Bert
                                            One more time I have learned something reading this forum,
                                            Tank you all
                                            Salutations (Best regards) Bert
