    Circles and round lathed objects
    24 Posts 5 Posters 3.4k Views 5 Watching
      AG,
      your first method (creating a face to draw on) was quite intuitive - I do the same all the time. In the tutorial, as you can see, the view is almost horizontal; that's how SU "tries" to assume on which plane you are trying to draw. So when you are looking "down", it will draw on the red/green plane, if you are looking rather from the "side" (with the horizon more or less in the middle), it will try to draw on the red/blue or green/blue plane (depending on which direction you are looking).
      This is sometimes harder to do than what you did.
      RoundedCorner_tut.skp
      As for the rounded corner stuff, see a "Tutorial" below (go through the scenes)
        Hehe, Mike - just "cross posting..."
        πŸ˜„
          mike d
          that ok gai as long as we get his questions answered
          The grass is always GREENER on the roof.
          • N Offline
            not registered yet
            Quickly...thanks for the replies. Yes, Mike, I did look at your drawing, and that was one of the things I was trying to do.
            The other was turning a square corner with the follow-me tool. If you looked at my successful rounded corner rendition it was on the side of a box. I had wanted to go around the outside of the top horizontal plane of the box. Follow-me wouldn't take that order, but hit the corner and continued down vertically. I just have to adjust my mindset to make it right.
            Now I'll go have a look at the tutorial. πŸ˜„
            P: AcousticGarden
            • boofredlayB Offline
              boofredlay
              AG, I created another tut for the follow me. If you are going around the perimeter of a surface, no need to select all the lines, just the surface.
              Check it out.
              FollowMeTut.skp
              • N Offline
                not registered yet
                Oh, I just noticed Boofred's post. That's probably good, because I tried following the tutorial, but there's a step missing. I have the separated plane for follow-me to use, and I had all the edges selected, but I don't know what to click follow-me on to make it work. Also, the edges seem to de-select when I hit the follow-me tool.
                I'll check out the new tutorial now.
                P: AcousticGarden
                • N Offline
                  not registered yet
                  Wow Eric! Your end result was the coolest architectural gutter system ever! πŸ˜†
                  Now, my turn to try...
                  P: AcousticGarden
                    You select the face of that small profile with the follow me tool.
                    Don't bother with the edges deselecting - they do this all the time! πŸ˜„
                      That's nice, Eric - and also highlights the drawbacks of the follow me tool with very sharp angles.
                        boofredlay
                        I went ahead and added this tut to the Tutorials & How-To / Modeling Forum.
                        • N Offline
                          not registered yet
                          Worked like a charm. The selected face was visually de-selected upon choosing the follow-me tool, but it worked when I clicked the plane I wanted to border the top plane with.
                          P: AcousticGarden
                            boofredlay
                            Yea, like Gai said, the surface or edges seem to be deslected when you grab the Follow Me tool.
                            Glad you got it to work for you.
                            • N Offline
                              not registered yet
                              Oh, I just realized another thing I'm curious about: Can you grab an object, and move it without distorting it? Like say you were doing an interior furniture layout. Could you move a complete piece of furniture in tact without the program trying to distort the object? I haven't seen a way to do that yet.
                              P: AcousticGarden
                                boofredlay
                                You have to make sure the "furniture" or whatever it is you want to move is separated from the rest of the model. To do this you make a group or component.
                                Check out the SU 5 tutorials on the SketchUp site. #22 will talk about components but check them all out. This is how I learnt. πŸ˜„
                                http://sketchup.google.com/gsu5vtvideos.html
                                Then check out the SU 6 Tutorails:
                                http://sketchup.google.com/gsu6vtvideos.html
                                • N Offline
                                  not registered yet
                                  Thanks. I think I've seen all the Sketch Up 6 tutorials.
                                  I didn't bother with all the SU5 ones believing that the changes in 6 might make those obsolete. I'll check out the one you recommended as soon as I can.
                                  So much to learn! πŸ˜„
                                  P: AcousticGarden
                                    ...I didn't bother with all the SU5 ones believing that the changes in 6 might make those obsolete...
                                    Never think they are - most of the "basic" techniques are the same.
                                    Also, there is a lot of things to update among the tuts - as well as the SU Guide which I also warmly recommend to go through...
                                    • N Offline
                                      not registered yet
                                      The guide being the pdf book? I think I'm a little less than half way through that.
                                      P: AcousticGarden
                                        Well, it has a pdf version, too (I have never printed it nor I have a printer actually) so I guess it is.
                                        A great resource.
                                          Bert
                                          One more time I have learned something reading this forum,
                                          Tank you all
                                          Salutations (Best regards) Bert
                                            Bert, that's what we are all here for; learning and sharing...
                                            I have learnt a lot from this or the "old" and even the "Freee GGroups" forums...
