    Weird behaviour
    9 Posts 6 Posters 1.5k Views 6 Watching
    • EdsonE Offline
      Edson
      there is something weird happening in my machine. I have installed mirror 3.1 but it does not appear in either the Plugins menu or the Context menu. in its stead i get miroir de la selection which is also a mirroring script but certainly not the one that I installed.
      I suspect it may have to do with some older script I had there but I just do not know how to get rid of it. any clues?
      edson
      http://www.mahfuz.arq.br
      • TIGT Online
        Didier's site seems to have a glitch with Mirror.rb - 'lost in translation'. The imperial AND metric versions should be the same, except that Didier translates the text/prompts to French in his metric version. Either version will work in any units. You can get the English one from: Dead link
        Save this into the Plugins folder - it's Mirror.rb: delete any similar files in that folder, e.g. Mirror3.1.rb...
        • EdsonE Offline
          Edson
          thanks, tig
          the french name went away but there still is something weird going on. what you can see in the attached picture is the result of clicking twice along the green axis (and thus defining a line parallel to it) and then return. it did mirror the box but the new one is below the ground plane. what could be the reason for that?
          edson
          http://www.sketchucation.com/forums/scf/sas/Ruby/Picture%206.png
          • Didier BurD Offline
            Didier Bur
            Thanks for the info, this is an error (misnamed file). Obviously there should be an english version instead 😳
            Will fix that on Monday.
            RickW and TIG are you the SAME person really 😮 😮 😮
            DB
            • N Offline
              not registered yet
              Where can I download it?
              [Invader ZIM]
              • TIGT Online
                ...the french name went away but there still is something weird going on. what you can see in the attached picture is the result of clicking twice along the green axis (and thus defining a line parallel to it) and then return. it did mirror the box but the new one is below the ground plane. what could be the reason for that?
                edson
                I can't get that error to occur on my PC. What's your platform, version of SUp, units, size/scale of cube etc ?
                • EdsonE Offline
                  Edson
                  tig,
                  i use an iMac Core 2 Duo (Intel processor), running mac os 10.4.9, units: meters, dimensions of the box are the standard ones offered by the dialogue (width 1.8, height 1.5, depth 1.2), SU Pro 6.0.514.
                  edson
                  • jujuJ Offline
                    juju
                    Where can I download it? 😄
                    From the link provided in Didier's signature.
                      RickW
                      Or from the direct link in TIG's post. It's that line of text that's bluish in color.
                      RickW
                      [www.smustard.com](http://www.smustard.com)
