    Request: Automatically add ConstructionPoint at Center of Ci
    13 Posts 7 Posters 4.0k Views 7 Watching
      RickW
      John,
      Yes, this can be done. I'll see if I can come up with something.
      RickW
      www.smustard.com
        RickW
        I should have said, "Yes, theoretically, it can be done."
        Reality is BugSplatting 😢
        Conversing with the SU crew about the issue...
        RickW
        www.smustard.com
          In principle you'd have some 'observer' auto-made in each model that's watching for new geometry to be added. If it forms an arc or circle a simple script adds a centre point ?
            azuby
            Isn't is possible to observer the Circle Tool itself? Or subclassing the Circle Tool?
            azuby
            *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
            Bad English? PM me, correct me. :smile:**
              Jim
              azuby
              I don't think you can observe a Tool. You can observer the Tools class.
              But, I think by using both a ToolsObserver and a ModelObserver, you can get to where you want to be.
                azuby
                Oh, you have to differentiate between "collection of tools" and "class of Tools"
                The class of Tools is Class, Tools itself is a class. What you mean is the collection of one tool and one more tool -> tools (not Tools). I do mention that, because we are in the Ruby forum and Ruby programmers would come in semantic conflict by the words.
                This is, what the spec says: "The Tools class contains methods to manipulate a collection of SketchUp tools." - that means a collection of - hm - circle tool, square tool etc. This classs do provide an add_observer method, so that you can register an object to a collection of tools, which gets notified of changes in the collection.
                Your are right, there does not seem to be a way of registering an observer to a Tool object. Also subclassing the circle tool does not seem possible, because I can't reach the circle Tool object.
                Maybe there is a way adding a Tools observer to the tools collection where the circle tool is in.
                azuby
                  Jim
                  In my example, you would need a 3rd observer - EntitiesObserver - to get the entities to add the center point to.
                  The following attachment adds these 3 observers and outputs debugging info to the Ruby Console.
                  observer_ex.rb
                  • N Offline
                    not registered yet
                    At jim & TIG
                    Not strictly on topic, but I'm trying to figure out how to write observers for a script of my own. I can't seem to find any kind of observer documentation anywhere; is there such thing as a formal observer? Jim's example above seems to indicate there is, and is the closest example I've got so far. So; how would I write a camera observer that calls a specific function every time the camera is moved (manually or by another tool/script)? Would that be something like "class CameraObserver < Sketchup::ModelObserver" with some camera specifc code thrown in?
                    I also need a Tools observer; how do I activate a constraint for each drawing tool based on (3Dpoint) information from the first click? Would that work better as a tool observer or a onLButtonDown action? I want something fairly efficient for this one; I don't expect the camera to be moving much for this plugin so I'd rather tie this to tools or clicks than to the camera.
                    Any suggestions, code, or links to observer documentation
                    Censored to protect your privacy Rick - I'm trying to use this for the 2D idea; any ideas or suggestions on how to best implement this?
                    [birchins]
                    • N Offline
                      not registered yet
                      I usually draw the circle using the Circle Tool first and then use "Get Midpoint" because I have "midpoint.rb". 😆
                      [Invader ZIM]
                        RickW
                        You want to create a view observer (not a camera observer, since those don't exist). The general form is:
                        1. create the observer, deriving from the appropriate template
                        2. attach the observer to the appropriate object
                        In your case, this would take the form of
                        class MyViewObserver < Sketchup;;ViewObserver
                          def onViewChanged(view)
                            # do stuff here
                        $myViewObserver = Sketchup.active_model.active_entities.add_observer(MyViewObserver.new)
                        #assigning to a global variable is optional, but allows you to remove the observer later
                        #you could also create a class variable to store the various instances, or there are other possibilities as well
                        Hope that helps...
                        RickW
                        www.smustard.com
                          RickW
                          The Tools observer has some problems - "toolname" is truncated on the Mac, making it hard (or impossible) to get the active tool based on name. However, the toolid works fine.
                          class MyToolsObserver < Sketchup;;ToolsObserver
                            def onActiveToolChanged(tools,toolname,toolid)
                              #do stuff here
                              puts "Selected tool; #{toolid} ;; #{toolname}"
                          Sketchup.active_model.tools.add_observer(MyToolsObserver.new)
                          That said, to constrain drawing to a 2D plane will probably require recreating all the tools with the constraints built in. 😞
                          RickW
                          www.smustard.com
