    New: HouseBuilder metric 1.2 (customizable)
    44 Posts 14 Posters 16.6k Views 14 Watching
      Daniel S
      In my case i still cannot see the icons in the toolbar (like in previous versions of housebuilder)... It works well, but i can´t view the icons...
        Jan Vdb
        Hi, Didier
        Have the same problem as Daniel.
        Have clearly carried out the instructions of the readme file, but still can't see any icons.
        Work with a PC. (AMD Athlon 64 X2 Dual Core processor 4200+ /NVIDIA Geforce 7800 GT SLI)
        Thanks, Jan Vdb
        • Didier BurD Offline
          Didier Bur
          Hi Kmead,
          I run on Mac OSX so that may be some part of the issue
          That's true, but my fault 😳
          The text file "housebuilder_section.txt" is loaded from a path which is hard-coded and I suppose it is different on PC and Mac.
          What the program does is that it searches the SU executable and it adds "Plugins/HouseBuilder" to the path
          of the exe to find the text file.
          What is the absolute path by default to the SU executable on a Mac ?
          And what is the relative path of the HouseBuilder folder ?
          Thanks for helping me to fix this problem.
          DB
            Didier Bur
            Hi all,
            I've released a new set of icons at the depositary (same post than the main prog).
            Tell me if this one works for you 😒
            Reagards,
            DB
            • EdsonE Offline
              Edson
              didier,
              sorry, but I could not find them.
              edson
              http://www.mahfuz.arq.br
              • jujuJ Offline
                juju
                emahfuz, go to the link in the post at the top of this thread, look for the attachment called hb_icons.zip and download. Next find your SU installation folder, go to plugins > housebuilder folder, copy icons extracted from the zip file provided into said folder. 😉
                  Jan Vdb
                  Hi, Didier
                  Sorry to say that the new icons don't make any difference
                  Greetings, Jan Vdb
                    Daniel S
                    Hi Didier,
                    I install the new icons but still no lucky...
                    i´m runing SU in PC with windows (but spanish version, maybe that´s the problem)
                    The absolute path by default to the SU executable is:
                    C:\Archivos de programa\Google\Google SketchUp 6\SketchUp.exe
                    I think that everyone has "Program Files" instead "Archivos de programa"
                    Daniel S
                      Didier Bur
                      What's going on with these icons
                      Still searching.
                      Anyone has my layer manager script with similar problems ???
                      DB
                      • kmeadK Offline
                        kmead
                        Didier:
                        On a Mac the path will always be:
                        /Library/Application Support/Google Sketchup 6/Plugins/Housebuilder/housebuilder_sections.txt
                        if that helps.
                        Many thanks, I haven't been by earlier so my apologies for taking so long to post the info.
                        I was looking at the old housebuilder and the ruby wasn't encoded like it is now or I would have tried chasing this myself.
                        Many thanks and have a great day.
                        Karl
                        I created Dilbertville, sorry about that...
                        • jujuJ Offline
                          juju
                          I've installed ruby as directed, activated the housebuilder menu under the view functions, also replaced the images with the new - still no icons though...
                            Didier Bur
                            SORRY all for the inconvenience (related to icons) 😳
                            I think I've got the solution: for an unknown reason scrambled extension code doesn't seem to work OK on some platforms (wether PC or Mac).
                            I'll publish in a few hours a "non-scrambled" main script to replace the 'offender'.
                            Regards,
                            DB
                              Didier Bur
                              💭 I'm sure this one will work !!!
                              Please download it at the depositary and re-install ALL files.
                              Regards,
                              DB
                                Daniel S
                                Now I can see the icons!!!
                                Thank you Didier!!! 😄
                                Daniel S
                                  azuby
                                  Didier, some hint for the encrypted/scrambled version: The code is executed through "eval" and so some file infos are missed. If you want to build a nearly fully encrypted version, you can write a simple non-encrypted Ruby file, which only sets a global constant (make sure you are not using a variable) like
                                  MY_FILEDIR = File.dirname(__FILE__).gsub(/[\\\/]/, File;;SEPARATOR) << File;;SEPARATOR unless defined? MY_FILEDIR # all in one line
                                  Within the encrypted file you -> require the non-encrypted file and are done. Say you have
                                  • my.rbs
                                  • my/mypath.rb
                                    than you require like this:
                                  require 'my/mypath.rb'
                                  The "defined?"-thing is done to avoid possible redefiniton of the constant - that would raise an error (or give a warning, not sure).
                                  edit: One regular expression and one gsub is enough 😉
                                  azuby
                                  *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
                                  Bad English? PM me, correct me. :smile:**
                                  • kmeadK Offline
                                    kmead
                                    Didier:
                                    I still get:
                                    Error Loading File HouseBuilder_extension.rb
                                    private method `split' called for nil:NilClass
                                    When SU starts and although one can bring up the House Builder tool pallette, it won't actually do anything when one clicks on the buttons.
                                    Sorry for being a wet blanket
                                    Karl
                                      Jan Vdb
                                      Hi Didier,
                                      Works now perfectly!! Thanks 😄
                                      Karl,
                                      Had the same problem as you, removed every housbuilder script from the plugin folder and did a re-install with the new script. Problem was solved.
                                      [Jan Vdb]
                                        Didier Bur
                                        Hi Kmead,
                                        I noticed that the path to HouseBuilder is wrong:
                                        Please rename the Housebuilder folder to HouseBuilder, because pathes are case-sensitive.
                                        Hope this will solve the problem 😉
                                        DB
                                          Daniel S
                                          Hi again Didier...
                                          It woks perfect but everytime when i do a right-click on a selection it makes an annoying "beep" sound.
                                          I remember that was a problem (?) of previous housebuilder´s versions, so i search in the old forum for an answer...
                                          if i put in the console:
                                          module UI; def self.beep; p caller; end; end
                                          the problem is solved... but when i restart SU6 i have to put it again in the ruby console.
                                          Another solution found in the old forum was to replace:
                                          UI.beep
                                          by
                                          #UI.beep
                                          in housebuilder. But i think that part is encrypted. Could you make this change for me?
                                          Thanks in advance,
                                          Daniel S
                                            Didier Bur
                                            Hi Daniel,
                                            Done. See depository and replace houseBuilderTool.rb in your HouseBuilder folder.
                                            Cheers,
                                            DB
                                            • 1 / 3
