    New: HouseBuilder metric 1.2 (customizable)
    44 Posts 14 Posters 18.9k Views 14 Watching
      Daniel S
      Hi Didier,
      I install the new icons but still no lucky...
      i´m runing SU in PC with windows (but spanish version, maybe that´s the problem)
      The absolute path by default to the SU executable is:
      C:\Archivos de programa\Google\Google SketchUp 6\SketchUp.exe
      I think that everyone has "Program Files" instead "Archivos de programa"
      Daniel S
      • Didier BurD Offline
        Didier Bur
        What's going on with these icons
        Still searching.
        Anyone has my layer manager script with similar problems ???
        DB
        • kmeadK Offline
          kmead
          Didier:
          On a Mac the path will always be:
          /Library/Application Support/Google Sketchup 6/Plugins/Housebuilder/housebuilder_sections.txt
          if that helps.
          Many thanks, I haven't been by earlier so my apologies for taking so long to post the info.
          I was looking at the old housebuilder and the ruby wasn't encoded like it is now or I would have tried chasing this myself.
          Many thanks and have a great day.
          Karl
          I created Dilbertville, sorry about that...
          • jujuJ Offline
            juju
            I've installed ruby as directed, activated the housebuilder menu under the view functions, also replaced the images with the new - still no icons though...
              Didier Bur
              SORRY all for the inconvenience (related to icons) 😳
              I think I've got the solution: for an unknown reason scrambled extension code doesn't seem to work OK on some platforms (wether PC or Mac).
              I'll publish in a few hours a "non-scrambled" main script to replace the 'offender'.
              Regards,
              DB
                Didier Bur
                💭 I'm sure this one will work !!!
                Please download it at the depositary and re-install ALL files.
                Regards,
                DB
                  Daniel S
                  Now I can see the icons!!!
                  Thank you Didier!!! 😄
                  Daniel S
                    azuby
                    Didier, some hint for the encrypted/scrambled version: The code is executed through "eval" and so some file infos are missed. If you want to build a nearly fully encrypted version, you can write a simple non-encrypted Ruby file, which only sets a global constant (make sure you are not using a variable) like
                    MY_FILEDIR = File.dirname(__FILE__).gsub(/[\\\/]/, File;;SEPARATOR) << File;;SEPARATOR unless defined? MY_FILEDIR # all in one line
                    Within the encrypted file you -> require the non-encrypted file and are done. Say you have
                    • my.rbs
                    • my/mypath.rb
                      than you require like this:
                    require 'my/mypath.rb'
                    The "defined?"-thing is done to avoid possible redefiniton of the constant - that would raise an error (or give a warning, not sure).
                    edit: One regular expression and one gsub is enough 😉
                    azuby
                    *error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
                    Bad English? PM me, correct me. :smile:**
                    • kmeadK Offline
                      kmead
                      Didier:
                      I still get:
                      Error Loading File HouseBuilder_extension.rb
                      private method `split' called for nil:NilClass
                      When SU starts and although one can bring up the House Builder tool pallette, it won't actually do anything when one clicks on the buttons.
                      Sorry for being a wet blanket
                      Karl
                        Jan Vdb
                        Hi Didier,
                        Works now perfectly!! Thanks 😄
                        Karl,
                        Had the same problem as you, removed every housbuilder script from the plugin folder and did a re-install with the new script. Problem was solved.
                        [Jan Vdb]
                          Didier Bur
                          Hi Kmead,
                          I noticed that the path to HouseBuilder is wrong:
                          Please rename the Housebuilder folder to HouseBuilder, because pathes are case-sensitive.
                          Hope this will solve the problem 😉
                          DB
                            Daniel S
                            Hi again Didier...
                            It woks perfect but everytime when i do a right-click on a selection it makes an annoying "beep" sound.
                            I remember that was a problem (?) of previous housebuilder´s versions, so i search in the old forum for an answer...
                            if i put in the console:
                            module UI; def self.beep; p caller; end; end
                            the problem is solved... but when i restart SU6 i have to put it again in the ruby console.
                            Another solution found in the old forum was to replace:
                            UI.beep
                            by
                            #UI.beep
                            in housebuilder. But i think that part is encrypted. Could you make this change for me?
                            Thanks in advance,
                            Daniel S
                              Didier Bur
                              Hi Daniel,
                              Done. See depository and replace houseBuilderTool.rb in your HouseBuilder folder.
                              Cheers,
                              DB
                                Daniel S
                                Thank you Didier! I have no more the "beep" 😄
                                And all the rest works perfect.
                                Thank you again,
                                Daniel S
                                • kmeadK Offline
                                  kmead
                                  Still not enjoying the love. Still suffer the same error on a Mac. Its no fun being a minority... 😉
                                    Didier Bur
                                    Hi Kmead,
                                    Let's try something else:
                                    Could you open the Ruby console and type:
                                    a = Sketchup.find_support_file("Sketchup.exe") ENTER
                                    and then type:
                                    a + "Plugins\HouseBuilder\" ENTER
                                    Please post the 2 results you've got, just to check if really it's a path problem or a backslash string problem or ❓
                                    Let's debug online... 😆
                                    DB
                                    • ton baetenT Offline
                                      ton baeten
                                      Didier,
                                      Since I have the same problem as Kmead on my Mac (with OSX 10.4.9), I followed this thread with great interest. I did what you adviced him to do. The results are: nil and Error: #<NoMethodError: undefined method `+' for nil:NilClass> (eval)
                                      But, maybe the problem is of an other nature:
                                      It was adviced to put everything concerning HouseBuilder in a separate folder under ..../plugins. So I did. Well, this is the only ruby to be stored in this way.
                                      There are more rubies extracting information from separate folders located in the pluginsfolder, but they all have an "open" xxxxx.rb file in the pluginsfolder (as a startingpoint !?), except Housebuilder.
                                      I am just a 'simple' Mac SU pro user, using a lot of rubies, so anything but a ruby-specialist. The only thing I can offer is help in performing any 'test' you would ask me for.
                                      with appreciation and greetings,
                                      Ton
                                      greetings,
                                      Ton
                                        Didier Bur
                                        Hi Ton,
                                        Thanks for helping me track the bug 😉
                                        If I'm not completely mad, I understand from your results that the method "find_support_file" doesn't work the same way on a Mac than on a PC 8O
                                        BUT just an idea comes to mind now: the Sketchup executable on Mac is not named "sketchup.exe" (no file extensions on Mac, right ?)
                                        That's why the method returns nil, eh eh...
                                        Could you try (sorry, no Mac here...) in the Ruby console:
                                        Sketchup.find_support_file("Sketchup")
                                        If it returns something else than nil, problem is solved. 😄
                                        Thanks again for helping,
                                        DB
                                          ton baeten
                                          Didier,
                                          I presume you are anything but 'completely mad'.
                                          Indeed, Macs never use the extension .exe that is pure MS windows (why didn't I think of that).
                                          I just tried Sketchup.find_support_file("Sketchup") in the ruby console and the result still is: nil
                                          So, still no solution. The last hour I just tried a couple of things, but found no solution.
                                          Could you please describe me what files (rubys and/or non-ruby) I need to/should have and where they should be located.
                                          For now, I have, located in my plugins folder a folder HouseBuilder_metric_1.2.
                                          This folder contains
                                          • HouseBuilder_extensions.rb
                                          • readme.txt
                                          • HousebuilderTool.rb
                                          • Housebuilder.rb
                                          • another folder called 'Housebuilder' containing:
                                          • a number of png's and gif's
                                          • HouseBuilder-extension.rb(gif)
                                          • housebuilder_sections.txt
                                            As mentioned before, everythings is within one folder. None of the ..rb files are in the plugins folder itself. Maybe that is why nothing can be found to start 'Housebuilder'.
                                          Open for further info and tests,
                                          Greetings,
                                          Ton
                                          greetings,
                                          Ton
                                            Didier Bur
                                            Hi Ton,
                                            I'm sorry to say that your files/folders organization is completely wrong...
                                            A ruby script doesn't find its way by itself, so there are some rules to follow in order to make it work 😉
                                            When I release a package I always save the folders information when building the Zip so the user have just to unzip it in his Plugins folder and that's it. No folder(s) creation needed, no file(s) renaming, no nothing.
                                            If you delete all "housebuilder" files you have installed and unzip the package again in your Plugins folder, it MUST work.
                                            After having unziped, you should have:
                                            • "HouseBuilder_extension.rb" in your Plugins folder, as well as "readme.txt"
                                            • a folder named "HouseBuilder" under the Plugins folder
                                            • in this HouseBuilder folder: all Gif's and PNG's, 2 rubbies and "housebuilder_sections.txt"
                                            If it doesn't work, I give up 🤓
                                            Hope this helps this time 😉
                                            DB
                                            • 2 / 3
