    Shortcuts Plugin Possible?
    19 Posts 5 Posters 9.7k Views 5 Watching
      Shaun Tennant
      TIG,
      I'm very glad you are here! - you guys are amazing. I get so tired of not having "a" as my add scene shortcut, and having to re-do the prefs or re-load my shortcut file.. Arrrgghhh. I don't know how many times i asked Google to fix this... Thanks for the tips on the registry though kindly appreciated!
      [Shaun Tennant]
      Whether they find a life there or not, I think Jupiter should be called an enemy planet.
      • Jack Handey
        Thanks. I saw cadfather's post just before leaving work. I copied the registry file after I had made the shortcut for adding scenes. It appears in the registry but I haven't found the secret to getting the shortcut activated from that saved file. I get messages asking me if I want to add that info to the correct registry but there's no change in SU. I've tried it before opening SU and after. So what am I doing wrong?
        Edited to add: the shortcut shows in the registry but doesn't show as set when I go to Window>Preferences>Shortcuts
        By the way, it's that Scene Add thing I'm after.
        • CadFatherC Offline
          CadFather
          on my computer it was quite simple - everything worked, toolbars layouts and keyboard shortcuts.
          (which differ much from google)
          i'm attaching 2 files cleaner and master. first back up the key (has to be this key and all inside) [HKEY_CURRENT_USER\SOFTWARE\Google\SketchUp6] on your pc. (ex. dave.reg)
          you can keep regedit open at the key > run cleaner.reg and you will see the key disappear.
          if you open SU now you will see the interface go back to default..
          and...there is a new key in the registry called.. guess what? [Sketchup6]
          now close SU and run cleaner.reg again > double click on the dave.reg key you saved before
          and start SU.......
          REGS.zip
            The two files in the zip file are SU_Clearer and SU_Training. Is that right?
            For some reason, after looking at the registry and attempting the moves from your other thread I am now getting Bug Splats upon closing SU. I was going to uninstall it all and reinstall but now I wonder if your cleaner should be run instead.
              Actually, I ran your cleaner and then went back and reset SU manually. that got rid of the bug splat.
                CadFather
                ..fantastic - i just went and tried it on a 'new' pc - it all worked..
                and on my daughter's laptop! all my settings, cuts, rubys... everything........my sketchup portable
                πŸ’š
                  So, let me see if I understand this. If I open SU and set the shortcut I want to add scenes and then export the entire SketchUp registry [HKEY_CURRENT_USER\SOFTWARE\Google\SketchUp6] and save it as dave.reg, I should be able to double click on dave.reg and then open SU to find that shortcut is still active?
                  What confuses me is that with SU closed the the Registry, under Settings shows there is a shorcut set for Pageadd: but when I open SU the shortcut doesn't work.
                    CadFather
                    that's strange because it does on mine...i mean all the others..let me try with add scenes..
                    who knows maybe a bug
                    wow, just tried (twice) the add scene doen't work 😲
                    mine is F12 i will try a different key
                      The SketchUp folks acknowledged awhile ago that there were a few user set shorcuts that don't stick after setting. Add scenes was one.
                      That is why I was hoping for a Ruby script that would run at SU startup (like the one that calls the Select tool instead of the Pencil) and set the shortcuts by reading the preferences.dat file that is generated when you click Export in the Shortcuts setting dialog box.
                      I use Alt+A to add a scene but it won't stick ether.
                        CadFather
                        got it - the problem is that it saves the key as 'add page'
                        instead we need it under 'View/Animation/Add Scene'
                        i have added it to the registry manually (saved the key) now it works
                        what key do you normally use?
                          Hmm. So how does that look in the Registry. In other words, what would I type to add that to mine?
                          The curious thing is that I have U set to updatescenes and it shows in the Registry as pageUpdate: and no reference to scene.
                            Ha! I got it! I edited the entry changing it from pageAdd: to View/Animation/Add Scene and now I have a shortcut.
                            Woo hoo! Thank you sir. Now we need to tell the world.
                              CadFather
                              that's right, @last folks must have forgotten to let google people know..
                              here's a ruby script that will tell you the proper name, you just have to write that over the unusable one.
                              πŸ€“
                              SHORTCUTS.zip
                                I think I have that one. I need to look.
                                Thanks again.
                                  CadFather
                                  the CadFather strikes again! πŸ’š
                                  EDIT: one more bug, if you go and enter a new (or the same) key for 'add scenes', 'update scenes' etc
                                  it will overwrite your tweak - however it will work as long as once you have set it you leave it alone.
                                  and that is the end for tonight
