[Plugin] VolumeCalculator v1.7
this script is awesome... calculation how much concrete in a foundation down to the last drop is awesome power...
thanks so much
TIG,
Thank you for updating your script with those 3 requests so quickly.
Outstanding service !!!
The new version of VolumeCalculator works really well.
Thanks once again
Regards
Howard Leslie -
Very very good tool, it is really something that I will use alot.
It works perfect, I like the layer options.[Haggai]
TIG,
I'm looking for your cut/fill calculation tutorial. Links in the Google forum no longer work.Thank you.
@archtrot said:
TIG,
I'll have it somewhere at home... I'll post it a soon as I find it !
Here it is attached...
TIG,
Dense question Alert!
Is there a tut on how to used it? -
@tobobo said:
TIG,
Is there a tut on how to used it?Open any .rb file in NotePad [or a similar plain text editor (NOT A word-processor)] and there is usually a set of instructions at the beginning...
Simply put: if you have a shape that you'd like the volume of, then make it a group or component. Select it and right-click to get the context-menu and near the bottom is the "Volume" option. Pick that and follow the instructions / options...
HOWEVER - when I just tried using now it Bug-splatted ! It was OK before and is unchanged - testing for causes...
EDIT: see http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1532 for the fix... -
Thanks very much.
Major Blonde moment
People, please do not discuss the scripts here, this is the repository. Use the regular Ruby subforum.
Locking this thread seeing that v1.8 is out already.
