    [Plugin] VolumeCalculator v1.7
    10 Posts 7 Posters 17.0k Views 7 Watching
      VolumeCalculator v1.7 script now uploaded.
      Options now include ability to choose the volume's layer, including making a new layer 'on the fly' if required, to hide/show the volume's face's edges, and to pick the volume's face colours from any standard colour or model material...PayPalButton
      VolumeCalculator.rb
      • KrisidiousK Offline
        Krisidious
        this script is awesome... calculation how much concrete in a foundation down to the last drop is awesome power...
        thanks so much
        By: Kristoff Rand
        • H Offline
          Howard leslie
          TIG,
          Thank you for updating your script with those 3 requests so quickly.
          Outstanding service !!!
          The new version of VolumeCalculator works really well.
          Thanks once again
          Regards
          Howard Leslie
          • H Offline
            Haggai
            Very very good tool, it is really something that I will use alot.
            It works perfect, I like the layer options.
            [Haggai]
              archtrot
              TIG,
              I'm looking for your cut/fill calculation tutorial. Links in the Google forum no longer work.
              Thank you.
                @archtrot said:
                TIG,
                Thank you.
                I'll have it somewhere at home... I'll post it a soon as I find it !
                Here it is attached...
                Cut+Fill.skp
                • ToboboT Offline
                  Tobobo
                  TIG,
                  Dense question Alert!
                  Is there a tut on how to used it?
                  Toby
                  Philippians 4:13
                    @tobobo said:
                    TIG,
                    Open any .rb file in NotePad [or a similar plain text editor (NOT A word-processor)] and there is usually a set of instructions at the beginning...
                    Simply put: if you have a shape that you'd like the volume of, then make it a group or component. Select it and right-click to get the context-menu and near the bottom is the "Volume" option. Pick that and follow the instructions / options...
                    HOWEVER - when I just tried using now it Bug-splatted ! It was OK before and is unchanged - testing for causes...
                    EDIT: see http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1532 for the fix...
                    • ToboboT Offline
                      Tobobo
                      Thanks very much.
                      Major Blonde moment
                      Toby
                      Philippians 4:13
                      • jujuJ Offline
                        juju
                        People, please do not discuss the scripts here, this is the repository. Use the regular Ruby subforum.
                        Locking this thread seeing that v1.8 is out already.
