    [Plugin] Skin.rb
    237 Posts 66 Posters 181.2k Views 66 Watching
      architectboy
      Baz, I just took the large pictures of the icons, colorized them to my liking, and made them fit for being buttons. So the work load is now off of you but if you already have them just put them up and we'll see which ones are better. And thank you, Thank you, Thank You! for the icons πŸ˜„ πŸ˜„ πŸ˜„
      The script is coming along nicely and here is a in-between version with non-branching lines working, and it has the icons too. Just unzip everything into the Plugins folder.
      Skin.zip
        Daniel S
        Thank you!!!
        It works with lines too!! A great script and very very usefull.
        Thank you!!!
        Daniel S
          architectboy
          Warning: the in-between versions are Very buggy ❗
            architectboy
            So, since I was getting slightly tired of programing I decided to take a break and show you guys just what the plans for future versions are. Each picture shows what that version will do in one operation. The current version is 1.8, working on 1.9.
              architectboy
              Here are the rest. And all the versions in-between 1.0 and 1.7 had slightly different ways of doing the same thing, until 1.7 finally allowed enough expansion.
              • bazB Offline
                baz
                ok ab here they are again with the colour change, exported without aa.
                baz
                edit: just saw yours, they look fine.
                  architectboy
                  Ahhh... Perfect πŸ˜‰ my colorizing left a odd tinge of pink in it but this will do very well.
                  • EdsonE Offline
                    Edson
                    hi archboy (what about giving us your name?),
                    each new post makes my mouth water more than the previous one. if you are doing this at 14 just image what you will be doing at 30!
                    cheers.
                    edson
                    http://www.mahfuz.arq.br
                      architectboy
                      So here is as close to version 1.9 as it's going to get because I ran into some trouble and think that it will be easier to fix it after changing to version 1.10 and beware that in-between versions are buggy! And as for my real name, it is in the copyright, and yes I to wonder what great things I will be doing at 30.
                      skin.zip
                        Darrel,
                        Brilliant script.
                        Nevertheless it gives me a "fakestart" eroor and from then on I have to click for every single edge to be created (and some more clicks/Enters for some reason).
                        Thanks anyway!
                          architectboy
                          Oops, sorry but I forgot to remove some debugging stuff 😳 , those message boxes are just checkpoints along the code to help me figure out where problems are, they don't mean anything.
                            OK, I deleted the two lines that launched the message boxes. The script works "fluently" now but actually does some irregularities; it does not start stitching from the point which would be logical for me. (See the attached picture)
                            Instead of the red edge another one from the next point on the circle (to the left) should go to the bottom right corner.
                              architectboy
                              There the problem comes up again. I saw it before but couldn't replicate it but apparently you re-found it so I can fix it, now that circles diameter is the same as the squares width, right?
                                Yes, exactly and it's aligned right above it.
                                It only does it where it starts stitching - all other lines are in the right place.
                                  architectboy
                                  Thanks for the info πŸ˜„ , it probably is being fixed in the (edited again) ENTIRE REWRITEof the code that I'm doing but I'll check for it when I'm done. Meanwhile you can just use the "Flip Edge" tool from the sandbox tools to fix it.
                                    Yeah, or just redraw that single line. Not a big problem anyway...
                                    Thanks for the script again and hope you can make it even more perfect.
                                      architectboy
                                      So, I was just wondering just how much people would be willing to pay for this script. It will be for free (don't worry πŸ˜„ ), but I just want to see what a reasonable price would be.
                                        Darrel,
                                        You probably know Smustard.com - you can see how much most of the "pay scripts" cost for some kind of a comparison.
                                          architectboy
                                          So, I went to camp last week and am just getting back to the script. Progress is currently slow, so please be patient. I will be releasing a half version soon, hopefully before Sunday, and probably with a question on some logic.
                                          And I think I have my info from the poll, could a moderator please remove it. Thank you. πŸ˜„
                                            Darrel,
                                            You should also be able to delete it by editing your first post but I deleted it for you now.
                                            I1m looking forward to the progress eagerly though don't want to "push" you.
                                            πŸ˜„
                                            • 11
                                            • 12
                                            • 2 / 12
