    [Plugin] Skin.rb
    237 Posts 66 Posters 159.4k Views 66 Watching
    • boofredlayB Offline
      boofredlay
      Welcome, we are glad you are here.
        Welcome and thanks for the immediate contribution!
        (My membership is also just pending... and pending...)
        • EdsonE Offline
          Edson
          hi archboy,
          welcome. may i ask what exactly does skin.rb do?
          regards.
          edson
          edson mahfuz, architect| porto alegre โ€ข brasil
          http://www.mahfuz.arq.br
          • jujuJ Offline
            juju
            Welcome to the board and thanks for the contribution. In order to make contributions more useful we have requested that persons submitting ruby scripts also explain their usage as posted here and here.
            Once we have these we can then add your scripts to the Ruby scripts depository.
            Thanks again.
              architectboy
              Well, when the script is done it will take two (maybe more, later) sides and connect them. To use it all that you would have to do is select the two sides and hit a button. For extra clarity, here are some examples, this one
              is not quite (in version 1.7) doable with the script (it works about half of the time) but this one
              was done with version 1.7 (not the latest version) of the script without any issues.
                RickW
                Welcome!
                Re: groups, I also had the "pending" issue. I finally ended up cancelling and re-joining, which worked. I now have access. But I still like it better over here than in groups...
                RickW
                [www.smustard.com](http://www.smustard.com)
                  architectboy
                  Yea, that worked for me to, just unsubscribe, resubscribe, tell them I'm leaving, And Unsubscribe! ๐Ÿ˜„ . And as for the script, here's version 1.8 with connecting faces mostly working now. And tell me if the upload didn't go well.
                  skin.rb
                    architectboy
                    Could someone who is good at graphic design make some icons for a tool bar for this script? I need 2 icons, one for the connect sides command, and another for a "clean selection" command (it's another one or those remove coplanar edges tools, but it removes faceless edges to), thanks for any help!
                    • bazB Offline
                      baz
                      heres a couple of quickie icons for discussion, Im not clear what the 'selecton' tool does tho.
                      baz
                        architectboy
                        Yes, I like the one for the connecting sides, thank you! And as for the clean selection tool it's hard to explain, put a picture is worth a thousand words, right? The reason that I included this tool is that I call it from inside the script.
                        Script Update: I think that I have just figured out why it wont successfully do lines ๐Ÿ˜’ (without the code to catch it) but since it is bed time I will go to bed and fix that tomorrow.
                        • KrisidiousK Offline
                          Krisidious
                          yes I've been digging the clean selection... it's awesome...
                          By: Kristoff Rand
                          • bazB Offline
                            baz
                            how about these?
                            baz
                            • bazB Offline
                              baz
                              here they are again at about the right size
                                architectboy
                                They are very nice and clear, I like them, thank you again. And if you can, would you make them the same colors as the standard ones to make them look more official (I don't think you would leave them pink). As, for the script, I didn't do much work on it today because it's my brothers birthday
                                • bazB Offline
                                  baz
                                  Happy to change the colour, not sure what you mean by 'standard' lotsa colours on the toolbars, (including pink ๐Ÿ˜„
                                  you choose, I think you need a bright colour tho.
                                  baz.
                                  ps: I love the way the spell checker thinks Im spelling 'colour' wrong! Ok color. happy now?
                                    architectboy
                                    Oh, well if you've seen pink ones that's fine with me, but I've only seen brownish ones so that's what I would be more comfortable with. And a bright color would probably make it easier to see, good idea. And should I put "Baz" in the credits or something else โ“
                                    ps: color is only spelled colour by the British (see http://www.dictionary.com)
                                    • bazB Offline
                                      baz
                                      its your call on the colour.
                                      I dont need a credit, glad to help you ruby wizards for a change.
                                      baz
                                        PeterCharles
                                        May I say how much I appreciate the skin.rb script. ๐Ÿ˜„
                                        I can use SketchUp to create both ends of sheet metal 'square to rounds', 'skin.rb' will join the points, 'jf_unfoldtool.rb' will unfold a flat pattern which I can export full size as a DXF profile and feed to a laser profiler.
                                        Magic ๐Ÿ˜†
                                          architectboy
                                          As for the color, I would like it brown like the ones that come with sketchup, just a little bit lighter though ๐Ÿ˜„ . Now I don't know why I must disagree so much with someone I'm grateful to for helping me, but if I don't put your name in the credits and say that I did it all by myself I would be lying, and I was just wondering if "Baz" would be good enough or if you would like you real name in there (or if "Baz" is your real name). And if you cant get the background to be transparent, just send it to me withought any antialiasing and I will erase the background then antialias it.
                                          • EdsonE Offline
                                            Edson
                                            i look forward to getting skinned.
                                            cheers.
                                            edson
                                            • 11
                                            • 12
                                            • 6 / 12
