    [Plugin] Skin.rb
    237 Posts 66 Posters 199.4k Views 66 Watching
      architectboy
      Yes, I like the one for the connecting sides, thank you! And as for the clean selection tool it's hard to explain, put a picture is worth a thousand words, right? The reason that I included this tool is that I call it from inside the script.
      Script Update: I think that I have just figured out why it wont successfully do lines πŸ˜’ (without the code to catch it) but since it is bed time I will go to bed and fix that tomorrow.
      • KrisidiousK Offline
        Krisidious
        yes I've been digging the clean selection... it's awesome...
        By: Kristoff Rand
        • bazB Offline
          baz
          how about these?
          baz
          • bazB Offline
            baz
            here they are again at about the right size
              architectboy
              They are very nice and clear, I like them, thank you again. And if you can, would you make them the same colors as the standard ones to make them look more official (I don't think you would leave them pink). As, for the script, I didn't do much work on it today because it's my brothers birthday
              • bazB Offline
                baz
                Happy to change the colour, not sure what you mean by 'standard' lotsa colours on the toolbars, (including pink πŸ˜„
                you choose, I think you need a bright colour tho.
                baz.
                ps: I love the way the spell checker thinks Im spelling 'colour' wrong! Ok color. happy now?
                  architectboy
                  Oh, well if you've seen pink ones that's fine with me, but I've only seen brownish ones so that's what I would be more comfortable with. And a bright color would probably make it easier to see, good idea. And should I put "Baz" in the credits or something else ❓
                  ps: color is only spelled colour by the British (see http://www.dictionary.com)
                  • bazB Offline
                    baz
                    its your call on the colour.
                    I dont need a credit, glad to help you ruby wizards for a change.
                    baz
                      PeterCharles
                      May I say how much I appreciate the skin.rb script. πŸ˜„
                      I can use SketchUp to create both ends of sheet metal 'square to rounds', 'skin.rb' will join the points, 'jf_unfoldtool.rb' will unfold a flat pattern which I can export full size as a DXF profile and feed to a laser profiler.
                      Magic πŸ˜†
                        architectboy
                        As for the color, I would like it brown like the ones that come with sketchup, just a little bit lighter though πŸ˜„ . Now I don't know why I must disagree so much with someone I'm grateful to for helping me, but if I don't put your name in the credits and say that I did it all by myself I would be lying, and I was just wondering if "Baz" would be good enough or if you would like you real name in there (or if "Baz" is your real name). And if you cant get the background to be transparent, just send it to me withought any antialiasing and I will erase the background then antialias it.
                        • EdsonE Offline
                          Edson
                          i look forward to getting skinned.
                          cheers.
                          edson
                          http://www.mahfuz.arq.br
                            architectboy
                            Baz, I just took the large pictures of the icons, colorized them to my liking, and made them fit for being buttons. So the work load is now off of you but if you already have them just put them up and we'll see which ones are better. And thank you, Thank you, Thank You! for the icons πŸ˜„ πŸ˜„ πŸ˜„
                            The script is coming along nicely and here is a in-between version with non-branching lines working, and it has the icons too. Just unzip everything into the Plugins folder.
                            Skin.zip
                              Daniel S
                              Thank you!!!
                              It works with lines too!! A great script and very very usefull.
                              Thank you!!!
                              Daniel S
                                architectboy
                                Warning: the in-between versions are Very buggy ❗
                                  architectboy
                                  So, since I was getting slightly tired of programing I decided to take a break and show you guys just what the plans for future versions are. Each picture shows what that version will do in one operation. The current version is 1.8, working on 1.9.
                                    architectboy
                                    Here are the rest. And all the versions in-between 1.0 and 1.7 had slightly different ways of doing the same thing, until 1.7 finally allowed enough expansion.
                                    • bazB Offline
                                      baz
                                      ok ab here they are again with the colour change, exported without aa.
                                      baz
                                      edit: just saw yours, they look fine.
                                        architectboy
                                        Ahhh... Perfect πŸ˜‰ my colorizing left a odd tinge of pink in it but this will do very well.
                                        • EdsonE Offline
                                          Edson
                                          hi archboy (what about giving us your name?),
                                          each new post makes my mouth water more than the previous one. if you are doing this at 14 just image what you will be doing at 30!
                                          cheers.
                                          edson
                                            architectboy
                                            So here is as close to version 1.9 as it's going to get because I ran into some trouble and think that it will be easier to fix it after changing to version 1.10 and beware that in-between versions are buggy! And as for my real name, it is in the copyright, and yes I to wonder what great things I will be doing at 30.
                                            skin.zip
                                            • 11
                                            • 12
                                            • 1 / 12
