    [Plugin] Skin.rb
    237 Posts 66 Posters 199.4k Views 66 Watching
    • jujuJ Offline
      juju
      Welcome to the board and thanks for the contribution. In order to make contributions more useful we have requested that persons submitting ruby scripts also explain their usage as posted here and here.
      Once we have these we can then add your scripts to the Ruby scripts depository.
      Thanks again.
        architectboy
        Well, when the script is done it will take two (maybe more, later) sides and connect them. To use it all that you would have to do is select the two sides and hit a button. For extra clarity, here are some examples, this one
        is not quite (in version 1.7) doable with the script (it works about half of the time) but this one
        was done with version 1.7 (not the latest version) of the script without any issues.
          RickW
          Welcome!
          Re: groups, I also had the "pending" issue. I finally ended up cancelling and re-joining, which worked. I now have access. But I still like it better over here than in groups...
          RickW
          www.smustard.com
            architectboy
            Yea, that worked for me to, just unsubscribe, resubscribe, tell them I'm leaving, And Unsubscribe! πŸ˜„ . And as for the script, here's version 1.8 with connecting faces mostly working now. And tell me if the upload didn't go well.
            skin.rb
              architectboy
              Could someone who is good at graphic design make some icons for a tool bar for this script? I need 2 icons, one for the connect sides command, and another for a "clean selection" command (it's another one or those remove coplanar edges tools, but it removes faceless edges to), thanks for any help!
              • bazB Offline
                baz
                heres a couple of quickie icons for discussion, Im not clear what the 'selecton' tool does tho.
                baz
                  architectboy
                  Yes, I like the one for the connecting sides, thank you! And as for the clean selection tool it's hard to explain, put a picture is worth a thousand words, right? The reason that I included this tool is that I call it from inside the script.
                  Script Update: I think that I have just figured out why it wont successfully do lines πŸ˜’ (without the code to catch it) but since it is bed time I will go to bed and fix that tomorrow.
                  • KrisidiousK Offline
                    Krisidious
                    yes I've been digging the clean selection... it's awesome...
                    By: Kristoff Rand
                    • bazB Offline
                      baz
                      how about these?
                      baz
                      • bazB Offline
                        baz
                        here they are again at about the right size
                          architectboy
                          They are very nice and clear, I like them, thank you again. And if you can, would you make them the same colors as the standard ones to make them look more official (I don't think you would leave them pink). As, for the script, I didn't do much work on it today because it's my brothers birthday
                          • bazB Offline
                            baz
                            Happy to change the colour, not sure what you mean by 'standard' lotsa colours on the toolbars, (including pink πŸ˜„
                            you choose, I think you need a bright colour tho.
                            baz.
                            ps: I love the way the spell checker thinks Im spelling 'colour' wrong! Ok color. happy now?
                              architectboy
                              Oh, well if you've seen pink ones that's fine with me, but I've only seen brownish ones so that's what I would be more comfortable with. And a bright color would probably make it easier to see, good idea. And should I put "Baz" in the credits or something else ❓
                              ps: color is only spelled colour by the British (see http://www.dictionary.com)
                              • bazB Offline
                                baz
                                its your call on the colour.
                                I dont need a credit, glad to help you ruby wizards for a change.
                                baz
                                  PeterCharles
                                  May I say how much I appreciate the skin.rb script. πŸ˜„
                                  I can use SketchUp to create both ends of sheet metal 'square to rounds', 'skin.rb' will join the points, 'jf_unfoldtool.rb' will unfold a flat pattern which I can export full size as a DXF profile and feed to a laser profiler.
                                  Magic πŸ˜†
                                    architectboy
                                    As for the color, I would like it brown like the ones that come with sketchup, just a little bit lighter though πŸ˜„ . Now I don't know why I must disagree so much with someone I'm grateful to for helping me, but if I don't put your name in the credits and say that I did it all by myself I would be lying, and I was just wondering if "Baz" would be good enough or if you would like you real name in there (or if "Baz" is your real name). And if you cant get the background to be transparent, just send it to me withought any antialiasing and I will erase the background then antialias it.
                                    • EdsonE Offline
                                      Edson
                                      i look forward to getting skinned.
                                      cheers.
                                      edson
                                      http://www.mahfuz.arq.br
                                        architectboy
                                        Baz, I just took the large pictures of the icons, colorized them to my liking, and made them fit for being buttons. So the work load is now off of you but if you already have them just put them up and we'll see which ones are better. And thank you, Thank you, Thank You! for the icons πŸ˜„ πŸ˜„ πŸ˜„
                                        The script is coming along nicely and here is a in-between version with non-branching lines working, and it has the icons too. Just unzip everything into the Plugins folder.
                                        Skin.zip
                                          Daniel S
                                          Thank you!!!
                                          It works with lines too!! A great script and very very usefull.
                                          Thank you!!!
                                          Daniel S
                                            architectboy
                                            Warning: the in-between versions are Very buggy ❗
                                            • 11
                                            • 12
                                            • 1 / 12
