    Archvision software
    11 Posts 6 Posters 3.6k Views 6 Watching
    • elmerE
      elmer
      Hi all,
      I would like to know if one of you is using this soft:
      http://www.archvision.com/
      and of course how you use it in your workflow and what you think of it.
      Thanks,
      Patrice
      • DanielD
        Daniel
        I've never used it, but while perusing their website noticed is not compatable with SU.
        My avatar is an anachronism.
        • elmerE
          elmer
          Yes Daniel I read that too, but it looks like it is PhotoShop compatible and I would like to know better about the way it can be used within PS.
          Patrice
            alexander
            You can download a plugin for PS.
            install and then in photoshop / file / automate you see the plugin.
            works nice 😄
              Allen Weitzman
              Patrice and others,
              Works well within Piranesi. Simport your SketchUp model, insert RPC elements, position them as you see fit not only in relative space front to back and side to side, but you can angle them (rotate) them as well. Especially nice with cars.
              Allen
              • P
                Phil Rader AIA
                I wish they had a plugin for SU that would work with Archvision RPC.
                http://www.philrader.com
                • elmerE
                  elmer
                  Thanks all for reply, had no time yet to play with ArchVision but will let you know what I get.
                  Phil, of course a plugin would be the best, let's hope one day may be....
                  Patrice
                  • P
                    Phil Rader AIA
                    Maybe a ruby guru can figure out a way to extract image files from the *.rpc file.
                    • Al HartA
                      Al Hart
                      You might take a look at IRender. It takes RPC objects, places them in SketchUp as low-geometry placeholders and renders then with the RPC
                      RPC objects placed as SketchUp components.
                      Object rendered with IRender
                      Al Hart
                      IRender nXt from Render Plus
                      • P
                        Phil Rader AIA
                        HMM...DO YOU HAVE A LINK TO iRENDER...ooops darn CAPS lock was on...a leftover from using autocad. Does anyone else do that too. When typing notes text etc. in autoCAD I use all caps just to keep the text easily readable but often I leave the caps lock on and start typing in other apps only to notice the all caps was on way after I began typing...Maybe I'm just getting old and senile.
                        anyway I'll try to find irender and have a looksee at it.
                        • Al HartA
                          Al Hart
                          IRender is at: http://forums.renderplus.com/wiki/index.php?title=IRender
                          You can download a trial version from: http://www.renderplus.com/pdf/download.htm
                          Let us know if you have any problems or need any helo..
                          IRender Plus currently works with .RPC files, but not with the new ArchVision "All Access" mode.
                          Al Hart
