    Depth Maps from SU
    47 Posts 14 Posters 24.1k Views 14 Watching
    • L
      lewiswadsworth
      I've figured out that if you really want to see how a fog-derived Depth Mask is really going to Export 2D, turn off hardware acceleration under Preferences. Big planes orientated near the horizontal seem to be subject to some odd streaking and abrupt shading changes that do not effect vertical surfaces. It's nothing that couldn't be corrected in Photoshop, but it does make this a little less acceptable a substitute for true Depth Map support in SketchUp. Oh well. Should I still write up a tutorial?
      http://www.sketchucation.com/scf/download.php?id=1501
      poster-Lewis Wadsworth
      col sporcar si trova
      • KrisidiousK
        Krisidious
        yes by all means because I am just barely following you...
        but as I see it... your target has the car included and that's throwing off the map... is the car actually inside your target mask?
        By: Kristoff Rand
        • K
          kdjanz
          I did do an export to EPIX and then changed the extension of the file to TIF. On the Mac, the file opened in Preview to show that there were 3 images inside. The first was the visible scene as in SU, the second was the grayscale depth map and the third was pure white - don't know what that was about. But I could then export the second image for my own use without ever going near Piranesi.
          Just thought that might be useful to you.
          Kelly
          poster-kdjanz
          • G
            gata
            Photoshop Elements has a plugin that enables many Photoshop features, like Channels http://hiddenelements.com/
            poster-gata
            • L
              lewiswadsworth
              Kelly
              EPix is supposed to be an extension to TIFF with two additional channels. I can force it to open in Photoshop, but all I find are the normal 3 RGB channels, unfortunately. What is Preview? I assume it is a Mac only program.
              --Lewis
              • L
                lewiswadsworth
                I actually have a license to Piranesi 3 for PC. I just happen to really dislike that application, enough that I never bothered to upgrade to more recent versions. But it is possible to export the depth mask only from Piranesi as a TIF or some other format. It needs to be adjusted slightly, because Piranesi makes nearer objects darker as opposed to lighter, and background in SU becomes some strange blood-red color in Piranesi's depth mask that needs to be selected and filled with white in Photoshop before it will work properly with anything in Photoshop.
                Here is the adjusted Piranesi-generated mask:
                and here it is applied in Photoshop using the lens blur filter:
                There are actually some buggy bits in the Piranesi depth mask as well...striations along the ground plane, and fringing of some kind along the roofline of the background building. Plus, of course, SketchUp's Epix exporter doesn't allow for antialiasing, which means that the depth mask produced from Piranesi has the same prevalent jaggies as the RGB image contained int the Epix file. In other words, with the exception of the problem with horizontal planes a depth mask produced using SketchUp's Fog, Styles, and Shadow controls is somewhat higher quality than one produced using Epix export from SketchUp via Piranesi.
                EDIT: I discovered that if you switch Piranesi's View menu > Depth and thenexport a "depth" EPix channel as some normal bitmap (like a TIF)--as opposed to doing that while View > RGB--you end up with a higher quality depth mask that merely needs to be inverted in PS to work properly with Lens Blur and similar techniques in Photoshop. You can combine that Piranesi-generated depth mask with a straight-from-SU6 2D export at the same resolution (and with antialiasing turned on) to get a nearly ideal depth mask situation.
                EDIT2: Okay, is anyone reading this and getting quite the same headache I am getting writing it? I think I'm going to call it a day and do something NOT involving depth masks and SketchUp for a while. I'll write up that tutorial tomorrow night.
                  Jackson
                  Lewis,
                  Sorry, I've been offline this weekend (I almost always am).
                  Yep, I see what you mean about the "depth map" exports- I got similar results. Bizarrely, when I exported now (with edges off) edges still show up in the exported jpg which I swear didn't occur last week.
                  Either way, neither of the bugs seem to affect the results enough to worry too much (although highly textured ground planes might show up the errors more dramatically). I've always found depth maps to be more of an art than a science so I'm not too worried about these glitches.
                  Jackson
                  Jackson
                  • L
                    lewiswadsworth
                    Lewis,
                    Jackson
                    I hadn't seen the edges bug, Jackson, but some tests I did yesterday seemed to implay that the "ground plane" problem doesn't really impact the use of the mask too much. I wish I could understand why it happens, though, since it is one of the few instances I have seen in SU where What You See Is NOT What You Get...the depth mask looks perfect on the screen. The ground plane problem doesn't seem to turn up if your ground plane is not particularly flat, or if the scale of the project is quite small, in any case. I'll write up the tutorial with some caveats about this.
                    I am curious to know though if all Mac users can really extract a true (or potentially true) depth mask from EPix exported files without owning a license to Piranesi. Could someone on a Mac check this? (See kdjanz' post above, first, about how he did that.)
                      Jackson
                      I should've said that the ground plane in my example was built geometry not SU's own ground plane. So it's not even a ground plane bug- it seems to be something to do with either orientation or angle of view relative to a viewed plane. Weird.
                      Jackson
                      Jackson
                      • GaieusG
                        Come on, guys, if you don't stop this, I'll move ya'all to the post processing how to forum!
                        πŸ˜„
                        Seriously speaking - don't you think if you elaborate this thread well enough, it should move there?
                        • L
                          lewiswadsworth
                          It wouldn't bother me to move it to post-processing. Jackson, do you mind?
                          (You're right, incidentally, we should call the bug the "horizontal plane error"...that's more accurate since I don't use SU's ground plane either.)
                            Jackson
                            Moved.
                            Jackson
                            Jackson
                            • takesh hT
                              takesh h
                              Hi Lewis, you are a busy guy.
                              I get both "the edges bug" and "horizontal plane error". πŸ‘Ώ
                              I tried this depth map thing a while ago and immediately I encountered the above problems.
                              Then I figured this cannot be done, but look at what you guys accomplished here...
                              I downloaded and used Lewis's style setting but got the same problem.
                              It could be my videocard problem (I use GeForce though).
                              There might be some workarounds for "horizontal plane error", but those edges are very difficult to get rid of.
                              BTW I found a nice tutorial of how those depth map should be applied to the original image.
                              This should save some of Lewis's time.
                              http://photography-on-the.net/forum/showthread.php?t=102294
                              Did you ever find a setting to get rid of edges, jackson?
                              poster-takesh h
                                Jackson
                                Takesh,
                                I must admit I've been too busy with boring stuff to have another go at doing these depth maps- I keep meaning to create a Style which incorporates the right settings. I didn't worry too much about the lines as it didn't have much of an effect on the blurring (as it bled over the lines anyway). I'll try to have another go at this this week.
                                Regards,
                                Jackson
                                • L
                                  lewiswadsworth
                                  Takesh,
                                  I've received your message and I sent you my test model. Let me know how it goes.
                                  You know what's odd? I've been using VRay a lot lately, and the quality of the depth mask it produces from an SU model (assuming we have no extraneous lines or whatever) is not better than what happens with this direct SU "cheat."
                                  --Lewis
                                  • takesh hT
                                    takesh h
                                    Thank you for your sample model, Lewis.
                                    I never imagined it was that big... the 18MB almost killed my PC.
                                    Now I know what I did wrong. I turned "use sun for shading" off.
                                    I discovered that either "shadow" or "use sun for shading" has to be on (even with both on, I got the same result).
                                    IOW the sun has to be there somehow, but shadows has to be erased by setting "dark slider" to the most right.
                                    Doesn't make much sense to me but it works.
                                    poster-takesh h
                                    • L
                                      lewiswadsworth
                                      Glad to help, takesh. For some reason I didn't get a notification that you had responded to this thread...so ignore the email I sent you asking if you had received the models.
                                      --Lewis
                                      • Mike LuceyM
                                        Mike Lucey
                                        Good thinking Lewis, thanks for this.
                                        Mike
                                        • C
                                          cymurai
                                          nice!!! such a great info.. thanks all
                                            rkitek
                                            I'm sure someone's already thought of this, but this just struck me. Another cool use for this technique... you can use your 2d export as a displacement map in your favorite rendering program.
                                            Here's an example of my test depth map in plan view with camera set to parallel projection(very quickly modelled terracotta roof tiles 😳 😞
                                            displacement map
                                            and the output when rendered on a single plane with it in the displacement slot and no diffuse:
                                            with out diffuse map
                                            and the output when rendered on a single plane with it in the displacement slot and a diffuse color map:
                                            with diffuse map
                                            fun stuff! πŸ’š
                                            • 2 / 3
