Modlumi - Easy 3D modelling
Yes for test if i have same result than you!
Pilou,
j'ai supprimé le fichier, et en effet, ce serait assez coton de retrouver la même situation où Modlumi ne veut pas faire le bevel sur une face circulaire standard...
Et l'autre exemple en capture vidéo où on voit que supprimer un bout qui dépasse d' une arête qui a bien une intersection détruit ma face contre toute logique -
Modlumi 0.25 is out: section planes, texture pins, soft edges and more
This is the biggest Modlumi release so far. You can now cut your model open, turn wood grain with pins, smooth faceted surfaces, and send your scenes around as a GIF. Most of it started right here in this thread, so thank you all.
Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.24 on Windows, it will offer you the update. The Mac build of 0.25 will follow later.
Cut through your model with section planes
Pick the Section Plane tool, point at a face (or press an arrow key to line it up with an axis), and click. Everything on the near side disappears and the cut edges are drawn heavy, so you can look straight into a room. Right-click a plane to turn its cut off and on, reverse it, or look straight at it. Scenes remember which planes cut, and section planes in your SketchUp files come along when you import them.
Section planes
Cut a model open with section planes to see inside it, show the cut heavier and filled, and save cuts in scenes.
Modlumi Docs (modlumi.com)
Position textures with pins
Right-click a textured face and choose Texture → Position. Drag the four pins to move, turn, scale, shear or distort the image. Turning wood grain to run along a board now takes one drag.
Texture positioning
Move, rotate, scale, shear and distort a material's image on a face with pins, and continue a texture across neighboring faces.
Soften and smooth edges
@Krass, this one's for you. Window → Soften Edges smooths the selected edges by the angle between their faces, so a faceted cylinder becomes a smooth one. The Eraser softens an edge with Ctrl and unsoftens it with Alt, and clicking a smoothed surface selects all of it.
Softening edges
Soften and smooth edges so faceted geometry reads as a curved surface.
Export your scenes as a GIF
@ntxdave, you asked whether scene playback could be saved to share. File → Export Animation records your scenes playing as a looping GIF, at the size and frame rate you choose. This is one, straight out of Modlumi:
Open, save and export
Open Modlumi projects and SketchUp files, save your work, copy and paste, and export images, animations and glTF models.
Your own fonts, and nicer labels
3D text can now use any font installed on your computer (desktop app), and the dialog previews the text in the model while you type. Text labels get a font, size and color in Properties.
Extrude, faster
@pilou, this one comes from your "so big request". After extruding several faces or edges, the new ends stay selected, so you can click again and keep going. Extruding a face along a direction you pick isn't in yet, but the arrow keys now lock a single face's extrusion to the red, green or blue axis, drawn in that axis's color.
A fresh look
View → Theme switches between Dark and Light, or follows your system. The whole interface is now set in Inter.
And also
- Snap outside the group. While editing inside a group or component, tools snap to guides and to the rest of the model.
- Combine Solids by clicking. Choose a command from Edit → Combine Solids with nothing selected, then click two solids. Subtract and Trim now cut with the first solid you pick, as SketchUp does.
- See before you confirm. Divide, 3D Text and Make Component preview their result in the viewport.
- Get the desktop app from the browser. A Download desktop app button in the web version gets the installer while your model stays open.
Fixes
- Erasing a curve's stub past a crossing erases only the stub. Before, it removed the whole curve and its face. Thanks @Krass!
- Bevel says why it can't bevel a loop. It draws the edge that is too short in red and stops at the largest size that fits. Thanks @Krass and @pilou!
- AltGr and Option characters. You can type characters such as @ on a French keyboard. Thanks @Krass!
- Extruding onto existing corners keeps soft edges and previews the whole result.
- Combine Solids on imported models succeeds more often.
All the details are in the release notes: https://modlumi.com/docs/release-notes/
As always, tell me what breaks and what you'd like next. Help → Report a Bug can attach your model.
Big release indeed!
LIttle big request ! Does it possible to have Size function aligned to an inclined face ?
Else works but it's a mess!
Keep Last face(s) extrude works fine! Bravo!
With next Size function aligned will be a killer one!
Request : Extrude with mouse direction!
(but i see that you speek about for a next release!
@pixelcruncher Greate release. I just installed so now I have to try some of the new stuff, and I am really looking forward to that.
One question I have though is what software do you use to create your animated gifs They are really great and you can add things like the keys and other stuff.
M majid referenced this topic
General Request : edit Points - now we have only Objects Volumes, Surfaces, Segments
and natural following "Subdivision" -
@ntxdave I made something myself (with AI help) to capture the Modlumi screen and keystrokes. It's a Frankenstein hack I put together so I can document things for Modlumi super quickly. It is tailor made for modlumi docs, not a generic program so I can't really help you out here.
edit: But maybe I should integrate this in modlumi itself so users can make their own little explainer gifs when reporting a bug?
He who can do the greater can also do the lesser!
Request
Can we have only wire ? (not with the faces)
(or maybe it's yet existing but i don't find it!
We want a true wire for help the Ai!
Yes ! thanks a lot
Once agin, thanks for your reply. I am attaching a link to something I think you might want to look at. It is a an example oh how to use a tool called Ksnip. In particular if you look at some examples at about the 7:00 minute mark. It might give you some ideas for your tool where we report problems. It has some interesting ideas
Here is a 2nd example with the instructions and the 0:30 minute mark shows what I wanted you to see.
Ksnip 2nd ExampleI have not installed or tried it. I saw what someone Les had posted on another thread in SketchUcation that I thought was interesting. In particular the way they referenced something they had posted.
Damned rest of my post was not sent!
So...
As you can see AI has some problem when the entiere wire is not present!
Will be better with the entiere real wire!
I created a box, did an offset on the fop face and then extruded the face so that I created a shape like you see in the image. I then used the Place tool so that I could show the model the way I wanted to see it.
So, as you can see in the image you will see the plane view of the simple model. Now for the silly question: how do I remove the plane outline so that it does not show if I want to share the image?
@ntxdave
Right Click on the Section Gizmo / Contextual menu / Hide
But any AI can do that! Prompt : erase axes, lines and make a futuristic sofa with cushions !
@ntxdave This is the child's game I was telling you about: send your ModLumi image (Drag and Drop) to an free IA (here Gemini https://gemini.google.com/app) And write or Speak a prompt (see above)
10 seconds after you obtain that you have asked!
What do you want more ? No hard learning curve, nothing to learn, infinite world of exploration!
And it's only "Still images" !
You can imagine for animation!
@ntxdave Of course in free it's only 7 seconds but you can make several and past them!
So following ... With sounds!
