[Plugin] LibFredo6 - v16.3b
I have trouble on using their plugins. I have tried using Curviloft but it did not do changes. Somehow, they are not working whenever I tried to use it. But I have already installed the LibFredo6. How do I fix this?
Your report is not very helpful for @fredo6 to resolve your issues.
To run any of Fredo's extensions you need to have installed [and restarted SketchUp] the newest versions of the following - the extension[s], LibFredo6 and the SketchUcation toolset [for the licensing].
If things are not working as expected, then open the Extensions > Developer > Ruby Console and report its output - copy-all+paste into a post. and also report any error messages which might appear...
Also - so that we might know details of your setup - please run this submenu item and copy-all+paste its result from the Ruby Console - Window > LibFredo6 Settings .... > Fredo6 Plugins Information for SketchUcation Support -
FredoTools v4.6a: Check the Computer Clock
This is my problem! Is anyone else experiencing this? It started ever since I updated the Fredo plugins (also in 2026).If I reinstall the previous versions, everything works fine. With the update, I get that error.
It only happens with all the plugins under FREDO6.
