    Modlumi - Easy 3D modelling
    401 Posts 9 Posters 67.9k Views 9 Watching
    • ntxdaveN
      ntxdave
      OK guys, not a great one but here is my first Modlumi animated video.
      Screen Capture Test 1.mp4
      As I said, not a great one but it is a start.
      Press F1...thank me later
        Clean! ๐Ÿ™‚
        ntxdaveN 1 Reply Last reply
        • ntxdaveN
          ntxdave @pilou
          @pilou Thank you sir but I have another silly question. How do you guys add your videos so that they are playing when the page loads?
          I cannot believe I have to ask a question that is that dumb. ๐Ÿ˜ž
            a gif can be send like a simple image!
            • KrassK
              Krass
              Hello,
              I can't bevel this other edges... don't know why.
              You report bug doesn't want to accept @ sign
              modlumi_EUcuuMRhcI.mp4
              • KrassK
                Krass
                other bug
                modlumi_t1RGl8rcDl.mp4
                  Have you a file ?
                  • KrassK
                    Krass
                    are you asking me?
                    • ntxdaveN
                      ntxdave
                      OK guys, here is my first attempt at creating an animated gif of one of my Modlumi models. I know this is not great but at least it is a start. Sometime pretty soon, I will try another one (if you do not laugh to loud). ๐Ÿ™‚
                      I should have added that the text about which view wa being shown was done in my video editor, not in Modlumi.
                      I do have (as is normal for me) a silly question. Is there a way so that it only plays one?
                      • KrassK
                        Krass
                        This post is deleted!
                          @krass
                          Yes for test if i have same result than you! ๐Ÿ™‚
                          • ntxdaveN
                            ntxdave @pilou
                            @pilou said:
                            @krass
                            What was the test?
                            KrassK 1 Reply Last reply
                              @ntxdave
                              Maybe there something in the modeling who explain the bug! ๐Ÿ™‚
                              Generaly a false size of something!
                              For your animation my little free Gif can't make an only one animation (infinite or yoyo yes ๐Ÿ™‚
                              So i go there where there are some free Gif Tools : https://onlinegiftools.com/stop-gif-loop
                              So here the result!
                              (If this is that you want ?
                              • ntxdaveN
                                ntxdave @pilou
                                @pilou Thanks but, not really. What I was thinking about was a wa to pause the gif or just have I ply once and then let the user/viewer decide if they want to see the animation again.
                                This, to me, is not about my gif in particular. In many cases when I see things on the forum where the posted is show how to some or how something works us viewers might want to pause the animation to see more details about what is being shown (kind of like a tutorial). With something like an MP4 video you can pause it.
                                Hope I am clarifying what I would like to see or figure out how to do/post.
                                  @ntxdave
                                  So... Try this one! ๐Ÿ˜‰
                                  https://gifplayer.app/
                                  • ntxdaveN
                                    ntxdave @pilou
                                    @pilou said:
                                    @ntxdave
                                    But I was really looking for a way to include pause and continue options for viewers on a web page.
                                    I think I have messed up this topic with my silly wishes when presenting info on a wen page.
                                    I do not want to distract from this topic. I am looking forward to more updates to Modlumi and want that to be goa
                                    Of this thread.
                                    • KrassK
                                      Krass @ntxdave
                                      Pilou,
                                      j'ai supprimรฉ le fichier, et en effet, ce serait assez coton de retrouver la mรชme situation oรน Modlumi ne veut pas faire le bevel sur une face circulaire standard...
                                      Et l'autre exemple en capture vidรฉo oรน on voit que supprimer un bout qui dรฉpasse d' une arรชte qui a bien une intersection dรฉtruit ma face contre toute logique
                                        • pixelcruncherP
                                          Modlumi 0.25 is out: section planes, texture pins, soft edges and more
                                          This is the biggest Modlumi release so far. You can now cut your model open, turn wood grain with pins, smooth faceted surfaces, and send your scenes around as a GIF. Most of it started right here in this thread, so thank you all.
                                          Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.24 on Windows, it will offer you the update. The Mac build of 0.25 will follow later.
                                          Cut through your model with section planes
                                          Pick the Section Plane tool, point at a face (or press an arrow key to line it up with an axis), and click. Everything on the near side disappears and the cut edges are drawn heavy, so you can look straight into a room. Right-click a plane to turn its cut off and on, reverse it, or look straight at it. Scenes remember which planes cut, and section planes in your SketchUp files come along when you import them.
                                          Section planes
                                          Section planes
                                          Cut a model open with section planes to see inside it, show the cut heavier and filled, and save cuts in scenes.
                                          Modlumi Docs (modlumi.com)
                                          Position textures with pins
                                          Right-click a textured face and choose Texture โ†’ Position. Drag the four pins to move, turn, scale, shear or distort the image. Turning wood grain to run along a board now takes one drag.
                                          Texture pins
                                          Texture positioning
                                          Move, rotate, scale, shear and distort a material's image on a face with pins, and continue a texture across neighboring faces.
                                          Soften and smooth edges
                                          @Krass, this one's for you. Window โ†’ Soften Edges smooths the selected edges by the angle between their faces, so a faceted cylinder becomes a smooth one. The Eraser softens an edge with Ctrl and unsoftens it with Alt, and clicking a smoothed surface selects all of it.
                                          Soften edges
                                          Softening edges
                                          Soften and smooth edges so faceted geometry reads as a curved surface.
                                          Export your scenes as a GIF
                                          @ntxdave, you asked whether scene playback could be saved to share. File โ†’ Export Animation records your scenes playing as a looping GIF, at the size and frame rate you choose. This is one, straight out of Modlumi:
                                          Exported scene tour
                                          Open, save and export
                                          Open Modlumi projects and SketchUp files, save your work, copy and paste, and export images, animations and glTF models.
                                          Your own fonts, and nicer labels
                                          3D text can now use any font installed on your computer (desktop app), and the dialog previews the text in the model while you type. Text labels get a font, size and color in Properties.
                                          3D text with an installed font
                                          Extrude, faster
                                          @pilou, this one comes from your "so big request". After extruding several faces or edges, the new ends stay selected, so you can click again and keep going. Extruding a face along a direction you pick isn't in yet, but the arrow keys now lock a single face's extrusion to the red, green or blue axis, drawn in that axis's color.
                                          Extrude improvements
                                          A fresh look
                                          View โ†’ Theme switches between Dark and Light, or follows your system. The whole interface is now set in Inter.
                                          Light theme
                                          And also
                                          • Snap outside the group. While editing inside a group or component, tools snap to guides and to the rest of the model.
                                          • Combine Solids by clicking. Choose a command from Edit โ†’ Combine Solids with nothing selected, then click two solids. Subtract and Trim now cut with the first solid you pick, as SketchUp does.
                                          • See before you confirm. Divide, 3D Text and Make Component preview their result in the viewport.
                                          • Get the desktop app from the browser. A Download desktop app button in the web version gets the installer while your model stays open.
                                          Fixes
                                          • Erasing a curve's stub past a crossing erases only the stub. Before, it removed the whole curve and its face. Thanks @Krass!
                                          • Bevel says why it can't bevel a loop. It draws the edge that is too short in red and stops at the largest size that fits. Thanks @Krass and @pilou!
                                          • AltGr and Option characters. You can type characters such as @ on a French keyboard. Thanks @Krass!
                                          • Extruding onto existing corners keeps soft edges and previews the whole result.
                                          • Combine Solids on imported models succeeds more often.
                                          All the details are in the release notes: https://modlumi.com/docs/release-notes/
                                          As always, tell me what breaks and what you'd like next. Help โ†’ Report a Bug can attach your model.
                                          ntxdaveN KrassK 2 Replies Last reply
                                            Big release indeed!
                                            LIttle big request ! Does it possible to have Size function aligned to an inclined face ?
                                            Else works but it's a mess! ๐Ÿ™‚
                                            Keep Last face(s) extrude works fine! Bravo!
                                            With next Size function aligned will be a killer one! ๐Ÿ˜‰
                                            Request : Extrude with mouse direction! ๐Ÿ™‚ (but i see that you speek about for a next release! ๐Ÿ™‚
