    Edges not showing
    5 Posts 3 Posters 160 Views 3 Watching
    • L
      Leggy
      Why are the vertical lines not showing
      L panixiaP 2 Replies Last reply
      • L
        Leggy @Leggy
        • L
          Leggy
          I’ve only noticed this in the last few months. I pulled the outer surface down 1mm then the lettering down 0.4mm and got this
            I expect the edges of the letters were welded. If they were it wouldn't matter what the softening angle was set to? Triple click on the geometry with the Select tool and then right click on it. Choose Soften/Smooth Edges. Set the slider to the default 20Β°.
            The edges of the L on the left were welded before using Push/Pull. The ones on the right were not.
            • panixiaP
              panixia @Leggy
              @Leggy It would be much easier to help you if you were able to take a proper full screenshot from your computer and phrase your request using complete coherent sentences. πŸ˜΅β€πŸ’«
