    First Rayscaper Test
    25 Posts 4 Posters 1.5k Views 4 Watching
    • L
      lightscape Newcomers
      @pixelcruncher
      I have seen the update of version 0.9.99.. After trying, I temporarily stopped my testing. I understand that Rayscaper is moving towards a more streamlined and simpler roadmap. But I cannot understand that the performance function of the material (The new standard material) will further shrink. All the suggestions I mentioned before regarding the organization are now only two:
      1. There are two modes for setting rendering sampling parameters: simple and advanced. The 0.9.99 version uses simple mode, while the previous version reverts to advanced mode.
      2. The material function (standard material) needs to be continuously improved in the future based on the existing foundation. I strongly recommend referring to the material system logic of Lighttracer, so that PBR can complete various material functions based on it (I don't understand why the necessary functions of semi transparency and anisotropy disappear in the new version)
        The material system of lighttracer is shown in the attached image, with reference to the left and right
      • KrassK
        Krass
        Hello, are you using a Mac?
        Krass
        L 1 Reply Last reply
        • pixelcruncherP
          pixelcruncher Extension Creator @lightscape
          @lightscape Sorry about that; that's a regression in the latest build.
          They should be in the advanced section, but I made some UI tweaks, and the advanced section now renders as hidden. This will be back in the next release.
          • pixelcruncherP
            @lightscape the 0.9.100 version is out which should work better.
            • L
              lightscape Newcomers @pixelcruncher
              @pixelcruncher
              Many thanks for you work!I will Try 0.9.100
              • L
                lightscape Newcomers @Krass
                @Krass
                No,i use windows
                • L
                  @pixelcruncher
                  I am recommending a designer around me to try Rayscaper. After discussing, we hope to add a scene setting function that can record the size, tone mapping parameters, environmental parameter status, etc. of each camera when it produces an image.. At the same time, different scene states can be rendered in batches at once.. This is the most desired feature to be added at this stage. Learn from the batch rendering function of Thea Render
                  • KrassK
                    Krass
                    For a batch render—and pending the availability of adjustable settings for each individual scene—you can currently render scenes using animation mode by setting the frames-per-second to the lowest possible value; this works very well, with automatic exposure.
                    Krass
                    • L
                      @Krass
                      Many Thanks!
                      • pixelcruncherP
                        @lightscape - Thanks for the feedback. I will look into batch rendering and save more settings with each SketchUp scene. @Krass 's idea is a workaround for now.
                        Cheers,
                        Thomas
                        • 2 / 2
