    Medeek Project
    118 Posts 3 Posters 17.0k Views 4 Watching
    • medeekM
      medeek
      And just for fun:
      I call this the "Mountain House". A sufficiently motivated framer (lots of money) could stick build this, I'm quite convinced.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Next is a test of the raised fascia offset:
        My question is what do we do in the field at this sort of corner?
        Also the same sort of thing at the re-entrant corner.
        design.medeek.com
        • medeekM
          medeek
          Looks like we will also need to add in hip walls for these "half hip" type roofs:
          I've also added in the Dutch Gable option for roof planes as well:
          This almost completes my work on complex roof in the house builder. Of course some additional work remains in connecting the House Builder to the Truss plugin's API. I will also need to enable the API with some new methods for complex roofs, but that work is relatively straightforward.
          Tomorrow I will look at the Roof Plan tab and probably add in a few more roof specific annotation options. Then from there we double check that the Print and DXF functions are wired up correctly.
          And then finally we move on to Foundations.
          However, this additional work on complex roofs has exposed the fact that I need to enable additional wall types in this app.
          design.medeek.com
          • medeekM
            medeek
            First look at some exterior trim applied to a couple "test houses". Corner trim, band board, skirt board and frieze board.
            design.medeek.com
            • medeekM
              medeek
              DXF output now enabled for Slab-on-Grade foundations.
              design.medeek.com
              • medeekM
                medeek
                Interior Bearing (ie. footing + post & beam) are now added to the House Builder.
                design.medeek.com
                • medeekM
                  medeek
                  First look at a basic Slab. The underlying code is very similar to a slab-on-grade so I should be able to complete this one more quickly.
                  design.medeek.com
                  • medeekM
                    medeek
                    First look at column footings:
                    design.medeek.com
                    • medeekM
                      medeek
                      First look at polyline stemwalls. Note that stemwalls and footings that are at the same Z height will auto merge for presentation purposes.
                      design.medeek.com
                      • medeekM
                        medeek
                        First look at a stemwall foundation with openings and a floor slab.
                        design.medeek.com
                        • medeekM
                          medeek
                          I've also enabled the entry stair option for foundation door openings
                          design.medeek.com
                          • medeekM
                            medeek
                            I'm now spending a day or two integrating the eight different foundation assemblies into the elevation views. Here is a couple examples of column footings:
                            design.medeek.com
                            • medeekM
                              medeek
                              I am now trying to wrap up stemwall foundations and the addition of windows, doors and blockouts, all within the elevation views. After further testing I'm noticing that all of this added complexity does potentially slow down the app/tool when enough windows, doors and dimensions are added. I will need to spend a few more days tightening up my "redraw" algorithms so that performance is maximized. The last thing we want is a sluggish interface.
                              design.medeek.com
                              • medeekM
                                medeek
                                I'm also adding gable walls as well as shed and hip.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Currently the various plan view tabs are treated as their own “sheets” or pages. In other words if you print that tab you get exactly what is in the viewport scaled to fit into a regular sheet size (letter, 11x17, Arch C, Arch D). You cannot add in other geometry from other tabs. This seems to work reasonably well for most of these plan views (ie. Floor Plan, Foundation Plan, Roof Plan, Floor Framing Plan etc…)
                                  However, when it comes to elevation views things typically get a bit more interesting. Some designers like to put multiple elevation views on one sheet and in some cases all four if they will fit ( I like to do this for small ADUs for example). So it is not as easy as assigning one elevation view to one sheet, or even assigning two elevation views to one sheet, there needs to be more flexibility.
                                  After giving this some considerable thought I decided what I really needed was a Layout system where the user can drag the elevations into the “workspace” and position them as they see fit, and then at that point add their annotations and dimensions. I have now created four additional Layout tabs where the user can do exactly that.
                                  The only major thing I feel like I am missing at this point is a sectional view or section tool.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    I've also add Common Truss Roofs along with Complex Roofs.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.2.8 - 10.11.2026
                                      • Added the "Draw House" tool to the Medeek Builder toolbar.
                                      I'm releasing this update so that interested parties can test out the House Builder interface. It is currently not fully wired into the Medeek API so have temporarily disabled the "Create House" button. I will be spending the next week or two completely the upgrades to the Medeek API for the various mdkBIM extensions so that we can access API methods for floors, foundations, roofs etc...
                                      The primary purpose of this update is to garner feedback on the UI and the front end. Please download and install this latest update and send any feedback directly to nathan@medeek.com. I will be very curious what everyone thinks of this new tool and I think you will find it is much more capable than the "prototype" Garage Builder".
                                      design.medeek.com
                                      1 Reply Last reply 👍
                                      • medeekM
                                        medeek
                                        Version 1.2.9 - 10.14.2026
                                        • Fixed a critical bug with the (Draw House) House Builder tool.
                                        • Added metric support for both the House Builder and the Garage Builder tools.
                                        If you are using the Garage Builder in metric mode you will need to update the Wall, Truss and Foundation extensions to the latest versions I have just released.
                                        If you try to use the previous versions of the plugins with the Garage Builder in metric mode it will create geometry that is corrupt and will probably cause SketchUp to bugsplat. Please uprade to the latest versions of these four plugins.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          I forgot to add in the temporary or construction dimensions. Working on that now.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            First look at some walls be generated by the House Builder. This is the easy part, next we need to add all the openings, and somehow make it very efficient.
                                            design.medeek.com
                                            • 5 / 6
