    Modelling a tramway
    595 Posts 43 Posters 449.2k Views 40 Watching
    • jo-keJ
      jo-ke
      I am still struggling with the best way of setting complex rails to my model.
      is the newest profile builder really the best way to setup complex rails with junctions and so on?
      here I have a typical project to solve:
      I have set the way for the rails and the proxy for followme.
      duew-depot1-1.skp
      http://www.zz7.de
        ProfileBuilder won't one-shot that network because there are so many branches.
        Here is what PB4 will produce if you try to loft the profile across that network or splines.
        duew-depot1-1_PB.skp
        • jo-keJ
          jo-ke
          Wow this one looks great.
          You used profile builder 4 and what did you do then?
          you took each part and do it one after one?
          http://www.zz7.de
            Rich O Brien Moderator @jo-ke
            I rotated your profile to lie on XY plane so I could assign it as a Profile.
            Then selected all the network of splines and used Build Along Path to create what you see in the file I shared.
            • jo-keJ
              jo-ke
              OK, I think I have to buy profilebuilder
              Thank you
              http://www.zz7.de
              • jo-keJ
                jo-ke
                http://www.zz7.de
                • jo-keJ
                  jo-ke
                  http://www.zz7.de
                  • jo-keJ
                    jo-ke
                    new vehicle created with meshyAI
                    http://www.zz7.de
                    Reply Quote 2
                    • KrassK
                      Krass
                      great ! The model and render are excellent!
                      But I don't understant why you use meshy ai ? It's a 3d model from photos service.? What ai model did you use for the render?
                      Krass
                      jo-keJ 1 Reply Last reply
                      • jo-keJ
                        jo-ke @Krass
                        @Krass
                        The model of the car was made with meshyAI. I took some views, meshyAI created the base model and I made some modifications.
                        The render was done with nano banana pro
                        http://www.zz7.de
                        • KrassK
                          Krass
                          Impressive. I always prefered tencent Hunyuan for modeling from photos, (20 free models per day!) but it seems you did well with meshy.
                          https://3d.hunyuanglobal.com/
                          Do you use Universal Importer (by Samuel Tallet) to Import the GLB files?
                          Krass
                          • jo-keJ
                            jo-ke @Krass
                            @Krass I import it to blender as glb and export it as dae to sketchup. It gave me the best results. sometimes glb are to heavy for SU to handle.
                            http://www.zz7.de
                            • jo-keJ
                              jo-ke
                              sketchup and AI- really good combination.
                              http://www.zz7.de
                              Reply Quote 2
                              • KrassK
                                Krass
                                Very nice
                                Krass
                                • jo-keJ
                                  jo-ke
                                  I remodelled the car, this time with SketchupAI modelling and the result should be used for 3D Printing. I came out surpriseingly good!
                                  SketchupAI: ist better for 3D printing, less geometrie
                                  meshyAI: better for rendering, heavy mesh
                                  render of the meshyAI Model with Gemini NanoBanana:
                                  http://www.zz7.de
                                  Reply Quote 3
                                  • KrassK
                                    Krass
                                    Yes! and the car on the right is a german Opel !
                                    Krass
                                      An Ascona, if my memory is working today.
                                      • jo-keJ
                                        jo-ke
                                        Maybe, but it is Nanao Bananas phantasy
                                        http://www.zz7.de
                                        • jo-keJ
                                          jo-ke
                                          3D warehousemodel S- Bahn Berlin
                                          http://www.zz7.de
                                          • KrassK
                                            Krass
                                            Hello,
                                            It's good, but this time that overly clean train doesn't fit well into the almost post-apocalyptic streets.
                                            Krass
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 29 / 30
