    Modelling a tramway
    595 Posts 43 Posters 449.2k Views 40 Watching
    • jo-keJ
      jo-ke
      old GDR impressions.
      http://www.zz7.de
      Reply Quote 2
        Brilliant.
        • jo-keJ
          jo-ke
          West Germany in the year 1950
          http://www.zz7.de
          • jo-keJ
            jo-ke
            West Germany in 1950
            http://www.zz7.de
            • jo-keJ
              jo-ke
              http://www.zz7.de
                Nice results. Strange to watch rendering change so much. It's now a text prompt.
                • jo-keJ
                  jo-ke
                  warehouse model, modified, rendered with nano banana.
                  Stuttgart 1982
                  http://www.zz7.de
                  Reply Quote 2
                    It nailed the era look!
                    • jo-keJ
                      jo-ke
                      Bridge- scene in fall at the 60ties
                      su model:
                      http://www.zz7.de
                      Reply Quote 3
                      • jo-keJ
                        jo-ke
                        I am still struggling with the best way of setting complex rails to my model.
                        is the newest profile builder really the best way to setup complex rails with junctions and so on?
                        here I have a typical project to solve:
                        I have set the way for the rails and the proxy for followme.
                        duew-depot1-1.skp
                        http://www.zz7.de
                          ProfileBuilder won't one-shot that network because there are so many branches.
                          Here is what PB4 will produce if you try to loft the profile across that network or splines.
                          duew-depot1-1_PB.skp
                          • jo-keJ
                            jo-ke
                            Wow this one looks great.
                            You used profile builder 4 and what did you do then?
                            you took each part and do it one after one?
                            http://www.zz7.de
                              Rich O Brien Moderator @jo-ke
                              I rotated your profile to lie on XY plane so I could assign it as a Profile.
                              Then selected all the network of splines and used Build Along Path to create what you see in the file I shared.
                              • jo-keJ
                                jo-ke
                                OK, I think I have to buy profilebuilder
                                Thank you
                                http://www.zz7.de
                                • jo-keJ
                                  jo-ke
                                  http://www.zz7.de
                                  • jo-keJ
                                    jo-ke
                                    http://www.zz7.de
                                    • jo-keJ
                                      jo-ke
                                      new vehicle created with meshyAI
                                      http://www.zz7.de
                                      Reply Quote 2
                                      • KrassK
                                        Krass
                                        great ! The model and render are excellent!
                                        But I don't understant why you use meshy ai ? It's a 3d model from photos service.? What ai model did you use for the render?
                                        Krass
                                        jo-keJ 1 Reply Last reply
                                        • jo-keJ
                                          jo-ke @Krass
                                          @Krass
                                          The model of the car was made with meshyAI. I took some views, meshyAI created the base model and I made some modifications.
                                          The render was done with nano banana pro
                                          http://www.zz7.de
                                          • KrassK
                                            Krass
                                            Impressive. I always prefered tencent Hunyuan for modeling from photos, (20 free models per day!) but it seems you did well with meshy.
                                            https://3d.hunyuanglobal.com/
                                            Do you use Universal Importer (by Samuel Tallet) to Import the GLB files?
                                            Krass
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 29 / 30
