    Edge Loop Insert – Insert loops like Maya/Blender
    36 Posts 7 Posters 2.8k Views 8 Watching
      Jianming Mo Newcomers @turbodizayn
      This post is deleted!
      J 1 Reply Last reply
        @turbodizayn Thanks for the feedback! Glad to hear both modes are useful – they'll both be in the final release, which is coming very soon.
        By the way, I have a quick question: can you guys see the demo GIF in my post? I uploaded it, but for some reason I can't see it on my end. Not sure if it's just me or if there's an issue with the upload. Let me know if you can see it – thanks!
          There's no embedded images. Maybe you uploaded too many and too large in size GIFs.
            Jianming Mo Newcomers @Jianming Mo
            bandicam 2026-08-17 11-40-20-452.gif bandicam 2026-08-17 11-40-50-879.gif bandicam 2026-08-17 11-41-22-334.gif bandicam 2026-08-17 11-41-50-682.gif bandicam 2026-08-17 11-42-17-748.gif
                Reply Quote 2
                  bandicam 2026-08-17 11-42-17-748.gif bandicam 2026-08-17 11-44-25-243.gif bandicam 2026-08-17 11-44-56-147.gif bandicam 2026-08-17 11-45-37-531.gif bandicam 2026-08-17 11-45-57-382.gif
                  1 Reply Last reply 👍
                  Reply Quote 2
                  • T
                    turbodizayn
                    Wow! It is cool!
                    • I
                      immaxy @Jianming Mo
                      @Jianming-Mo Interesting idea. I like that you’ve separated the topology-based and general geometry workflows instead of trying to make one mode handle everything.
                      For architectural users, I can see the geometry mode being especially useful when working with imported or imperfect models. I’d be interested to see how it handles heavier geometry and undo/recovery when a loop can’t be completed cleanly.
                      • G
                        Glenn at home
                        Very cool. Very similar to the Reshape tools in FormZ. Good job
                          Jianming Mo Newcomers @immaxy
                          @immaxy The plugin is still in the testing phase. I’ve tested it on simple and common models, and it works fine. For native SketchUp files, most models are not that heavy. I also think the geometry mode is quite practical. It can split non‑quad faces into standard quad faces. Thanks for your positive feedback. I will test its performance on complex geometry as well. Once the official release is ready, I hope more people can try it out and give me suggestions
                            Jianming Mo Newcomers @Glenn at home
                            @Glenn-at-home Thank you for your recognition. I will keep working on it.
                              Looks really nice. Does it respect Quadface quad convention?
                                Jianming Mo Newcomers @Rich O Brien
                                @Rich-O-Brien bandicam 2026-08-18 23-28-30-466.gif bandicam 2026-08-18 23-32-17-759.gif
                                Is this quad‑face based? Is this considered complex geometry?
                                  Can you share the rbz so I can test it? richob@sketchucation.com
                                  J 2 Replies Last reply
                                    @Rich-O-Brien In a few days I'll publish the plugin on Sketchucation. I'm currently adding a point positioning function to LoopCut, allowing users to input VCB values to set exact positions for loop cuts, which I consider essential.
                                    Reply Quote 2
                                      I’m back! After days of development, LoopCut’s VCB value input is finished. Let me show you how it works:
                                      Basic function: cut non-quad faces into clean quad faces with value input support. Double-click any spot on an edge to add a center cut line.bandicam 2026-08-23 12-10-01-375.gif
                                      Use percentages for positioning – enter 20, 30, 70 for 20%, 30%, 70% of the edge length (50 = center). Mouse dragging is also supported for visual positioning.bandicam 2026-08-23 12-11-35-622.gif
                                      For exact measurements, type values with units in the VCB. The edge under your mouse becomes the starting point: 0–49 references one end, 51–100 the other. Hover to pick your start edge, then type 1m or 200mm to get a precise cut.bandicam 2026-08-23 12-15-32-252.gif
                                      How do you like this VCB implementation?
                                        @Rich-O-Brien I have emailed the file to you. Please kindly check your inbox. Thank you for helping with the testing.
                                          [SHANA]bandicam 2026-08-28 23-41-25-934.gif SketchUp terrain meshes are now supported. For unknown reasons, lines generated when selecting different mesh points are sometimes incomplete. Anyone know the cause?
                                            Long time no see!
                                            LOOPCUT development update:
                                            QuadFace meshes are not supported at this time. I plan to look into adding support in a future release.
                                            Two new features have been added:
                                            1. Bulk insert loop edges: Use X + number shortcut
                                            2. Cut and Separate: Hold the ALT key while operating
