    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.4m Views 345 Watching
      Rich O Brien Moderator @fimo
      @fimo said in [Plugin][$] FredoScale - v3.6a - 01 Apr 24:
      What am I missing here ?
      Upload the file please so we can test
      • F
        fimo
        Sorry posted wrong door, try this one.
        Door glass panelled.skp
          Explode the 'glass' groups and group them into a single group then stretch
          • F
            fimo
            Many thanks Rich, that certainly works, my lack of lateral thinking on show right there.
            But is this a workaround for a non functionality in the extension or is it by design ? Just seems odd that it works in one plane and not the other.
              @fimo
              Dunno... it does behave correctly Left/Right. Just not Up/Down.
              In this video you can see it working as expected. Maybe @fredo6 knows more?
              • fredo6F
                NEW RELEASE: FredoScale v3.7a - 09 Jul 26
                Requirements:
                • LibFredo6 v15.9d.
                • Sketchucation PluginStore v5.0.7.
                FredoScale 3.7a includes changes for:
                • Bug fixing and adjustment for Dimension dialog box
                Home Page of FredoScale for information and Download.
                Main post of this FredoScale thread.
                • pep75P
                  pep75
                  I've installed the latest version of FredoScale, and I'm not sure it's really an improvement, at least not for me. Also, the fact that I have to manually turn off "Uniform" every single time is very irritating. Is there a way to change this so that Uniform is disabled by default?
                  fredo6F 1 Reply Last reply
                  • fredo6F
                    fredo6 @pep75
                    Improvement on what? There was a bug which was fixed so that it works as designed.
                    • pep75P
                      pep75
                      Well, it seems to me that the user interface has changed, or am I completely mistaken?
                      • pep75P
                        pep75
                        This is completely new to me, or am I wrong?
                        • fredo6F
                          This dialog always existed and is invoked by pressing Tab when the mouse is over a handle. Simply there was a bug for some situations.
                          alexpacio2013A pep75P 2 Replies Last reply
                          • alexpacio2013A
                            alexpacio2013 @fredo6
                            @fredo6 Great work. This latest “Uniform Scale” modification, although visually a small change, has actually been a major breakthrough for me. Congratulations!
                            1 Reply Last reply 👍
                            • pep75P
                              pep75 @fredo6
                              @fredo6 😐
                              I always got this dialog when pressed the tab and LOVED it!
                              Schermafbeelding 2026-08-16 150109.png.
                              When pressing ctrl- & shift I could scale uniformly. I don't see the improvement...sorry 😞
                              alexpacio2013A 1 Reply Last reply
                              • alexpacio2013A
                                alexpacio2013 @pep75
                                @pep75 This is the panel that appears with the button in the latest version 3.7a, with a tab in one corner of the box. It's improved because now you can disconnect the measurements.
                                • pep75P
                                  pep75
                                  Yes, I understand that, but I find it incredibly cumbersome. Every time I want to scale objects, I first have to disable the "uniform scale" option and then press Enter twice (which isn't a big deal). The way it was before worked fine; I wasn't missing anything at all.
                                  • alexpacio2013A
                                    @pep75 Before this change, when there was no uniform scale, it was impossible to unlock uniformity. This means that if you need to scale an object—for example, a chair that is not to scale—but you know one dimension, such as its height, you could resize the object by entering just that single dimension. For me, this is an extremely useful and precise feature. Previously, it was absolutely not possible to do this, whereas with SketchUp’s standard Scale tool it was possible, albeit in a less sophisticated way.
                                    Let me give you an example: if you insert a door, then change your mind and want to resize it while keeping it in scale, just by modifying the height with an exact measurement, how did you do it before? You just need to get used to it.
                                    pep75P 1 Reply Last reply
                                    • pep75P
                                      pep75 @alexpacio2013
                                      @alexpacio2013 In this situation I used the BOX stretch tool. Absolutely a must have tool in Sketchup. I always draw doors with a frame, so when you use the scale tool it also scales the frame, therefore the stretch tool is a better tool then the scale tool. Sorry but I did not mis anything and it worked like a charm.
                                      • fredo6F
                                        I will publish a change where the Uniform Scale checkbox is set to what it was when you last left the dialog.
                                        pep75P 1 Reply Last reply ♥
                                        • pep75P
                                          pep75 @fredo6
                                          @fredo6 Thanks! ♥
                                          • fredo6F
                                            NEW RELEASE: FredoScale v3.7c - 19 Aug 26
                                            Requirements:
                                            • LibFredo6 v15.9d.
                                            FredoScale 3.7c includes changes for:
                                            • Adjustment for Dimension dialog box
                                            pep75P 1 Reply Last reply 👍
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 58 / 59
