    ThruPaint Licensed Version 2.9 on Mac
    13 Posts 3 Posters 666 Views 3 Watching
      Maybe @fredo6 can shed some light on this.
      In the meantime if you open the Ruby Console and copy any errors that appear there. Share those errors messages here.
      Also run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and copy/paste that info here too.
      • K
        kaleen_pl
        Hi, what I found out is that when I reverted back to 2.8 the small toolbar which I can use to open materials browser was also not appearing. I had to downgrade the LibFredo as well to be able to use the plugin.
        My ruby console shows no errors at all.
        Plugins Information:
        Fredo6 Plugins Information on 2026-08-05 18:58:25 +0200
        - Platform: x86_64-darwin18 - Ruby: 2.7.2
        - Sketchup: 21.1.331
        - LibFredo6: v15.9d
        - LibFredo6 Binary loaded
        - Sketchucation Tools: 4.4.1
        - SCFLicense: v6.4a - 72
        - Fredo6 Plugins
            > ThruPaint v2.9a - licensed FULL
        Error: #<NoMethodError: undefined method `get_system_dir' for LibFredo6:Module>
        /users/michalkalinowski/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:875:in `info'
        /users/michalkalinowski/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:372:in `block in populate_support_menu'
        /users/michalkalinowski/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1569:in `block in add_command'
          Only thing that stands out is you are using an outdated Sketchucation Tools which could lead to licensing issues. I'd suggest upgrading.
          But if you open the Ruby Console while using ThruPaint it may output error messages that would also be helpful when @fredo6 see this thread.
          • K
            kaleen_pl
            I updated Sketchucation Tools, no improvement. The Ruby console is blank all the time, no errors there.
            • fredo6F
              On Mac, you MUST change the material via ThruPaint, not via the Sketchup Material browser, unlike what you can do on Windows. This is a limitation on Mac that has always been there.
              o, just click on the multi-color button to display the ThruPaint material browser and select another material.
              • K
                kaleen_pl
                Hi, I know this, but that is exactly the point, there is no multicolor button, there is no "small toolbar" that used to be in the left upper corner before i upgraded to libFredo 15.9d
                • fredo6F
                  When you start ThurPaint, what do you get on the screen?
                  • K
                    kaleen_pl
                    Have you seen the movie I attached to the first post? When I open it for the first time I get ThruPaint Material browser, but then when it dissapears there is no way to revoke it. Before I updated LibFredo there used to be a small ThruPaint toolbar with multi-color button used to revoke The Material Browser. Now there is no way to change the material, search for materials etc.. and ThruPaint becomes not usable.
                    • fredo6F
                      What happen if you click in the viewport?
                      • fredo6F
                        I found there was a strange bug, only present on Mac Intel. I fixed the issue in LibFredo6 v16.0a, just published.
                        • K
                          kaleen_pl
                          Hi Fredo, thank you. Your update solved the problem, but this was an ApplceSilicon Mac, Sketchup was running in Rosetta mode.
                          • fredo6F
                            Then it is even more puzzling. It has to do with detecting the dialog is visible on screen.... Maybe the emulation of Mac does behave a Mac Intel for that.
