    MOVEMENT THROUGH MACHINE
    8 Posts 2 Posters 435 Views 2 Watching
    • E Offline
      ericdjohn
      Re: [Tutorial] Animator Quick Start
      Subject: Animator (Fredo6) – Simple Beam Movement Through Machine Animation
      Hello everyone,
      I'm new to Animator by Fredo6 and am trying to create a very simple industrial animation for sales training purposes.
      I have a SketchUp model of a glulam beam sanding machine. The machine itself remains stationary, and I simply want to animate a glulam beam moving through the machine.
      My objective is:
      Beam starts at the machine entrance.
      Beam moves through the machine.
      Beam exits the machine.
      Eventually I would like to rotate the beam 90° or 180° and run it through again to demonstrate different sanding processes.
      The beam is a separate SketchUp Group and can be selected independently from the machine.
      So far I have:
      • Installed LibFredo6
      • Installed Animator v4.6a
      • Created a new film
      • Opened the Clip Editor and Positioner tools
      • Selected the beam group
      However, I cannot determine the correct workflow to create the first movement animation.
      When I open Positioner → Manage Positioners and click "Save current position as...", nothing appears to happen. No position is created and no prompt appears.
      What is the correct sequence of steps to:
      • Register the beam as an animated object (actor?)
      • Create a starting position
      • Create an ending position
      • Animate the beam moving from Point A to Point B
      • Preview and export the animation
      I am not trying to animate machinery, cameras, or complex assemblies. I simply need a beam to travel through a stationary machine.
      If anyone has a step-by-step example for moving a single group/component through a model using Animator v4.6a, I would greatly appreciate the help.
      Thank you.
      • E Offline
        ericdjohn
          You need to use the Clip Editor (first icon on toolbar) to use the GUI to add a Movement
          • E Offline
            ericdjohn
            Thank you, but how do you select the object to move
              Did you click New Movement?
              It will refactor the GUI to a dedicated Movement panel.
              The order of operation would be pick your transformation choice then select the object to apply that transformation to.
              You don't pre-select objects. Pick type then object to apply type.
              • E Offline
                ericdjohn
                got it thanks
                • E Offline
                  ericdjohn
                  I seem to be having problems making a MP4... probably doing something wrong. Is there an easy process?
                    Rich O Brien Moderator @ericdjohn
                    Did you install FFmpeg?
