    Fredo Curviloft Stopped Working
    5 Posts 4 Posters 264 Views 4 Watching
    • V Offline
      v_st
      Need help urgently. My Curviloft stopped working suddenly, review due in 5 hours!
      Below is the detail:
      Fredo6 Plugins Information on 2026-05-20 12:02:23 +0800
      • Sketchup: 26.1.256
      • LibFredo6: v15.9c
      • LibFredo6 Binary loaded
      • Sketchucation ExtensionStore: 5.0.7
        #<FrozenError: can't modify frozen #Class:SCFLicense: SCFLicense>
        c:/users/vincent_loh/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:322:in transfer_done' c:/users/vincent_loh/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:378:in initialize'
        c:/users/vincent_loh/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:81:in new' c:/users/vincent_loh/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe:81:in dynamic_token'
        c:/users/vincent_loh/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:824:in info' c:/users/vincent_loh/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:372:in block in populate_support_menu'
        c:/users/vincent_loh/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1569:in `block in add_command'
      • fredo6F Offline
        Please rollback to Sketchucation ExtensionStore v5.0.6. There is a bug in the new license update. Sorry for that.
        • V Offline
          v_st
          Thank you for the response!
          I accidentally found a workaround. The plugin sometimes works if I double-click the toolbar's button quickly.
            Sorry, but you need to get/install the current version of the SketchUcation tools [5.0.6] -
            a briefly available update was quickly found to be causing some users issues with their licensing.
            It's been reverted, but a corrected and updated version should be published soon.
            If you are still experiencing issues with this currently available version then please let us know, and well strive to fix things quickly...
            alexpacio2013A 1 Reply Last reply Reply Quote 0
            • alexpacio2013A Offline
              alexpacio2013 @TIG
              @TIG I installed version 5.0.6 but it still doesn't work
