Missing TT_Lib2 Extension
Subject: Request for TT_Lib² 2.12.0.rbz for SketchUp 2019
Message:
Hi all,
I’ve reinstalled SketchUp Pro 2019 on anew machine but over the years i find i no longer have my copy of TT_Lib² 2.12.0.rbz. I have not used it in a long while and have recently purchased and downloaded a TT package.
The TT version is required for CleanUp³ on SU2019, but it no longer appears to be available on SketchUcation, GitHub, or any archived links.Could someone please provide:
a working download link for TT_Lib2‑2.12.0.rbz, or
a copy of the RBZ if you still have it in your local Plugins folder?
Thanks in advance — much appreciated.
Stephen
We don't archive older builds unfortunately.
The current version 2.15.1 works fine with the latest version of CleanUp, up to and including v2026. What is your issue exactly ?
I haven't tried it on v2019 like yours, as I no longer have a copies installed older than v2023 - TT_Lib's EW page says, compatible >= v2022.
I suggest you try and contact @thomthom direct and ask if he has kept an archived version ? -
PS: I believed you... but if you go the the EW's page Github link to TT_Lib and go to this page:
https://bitbucket.org/thomthom/tt-library-2/downloads/?tab=tags
Scroll down to 2.10.2 and on the right click ZIP and an old archived version can be downloaded.
Then extract the ZIP file's contents. You only need the TT_Lib2.rb file and TT_Lib2 folder - ignore the rest.
Copy those two into your Plugins folder [you can open that using the Extensions > SketchUcation submenu item] and then restart SketchUp to sync. This old Lib is not 'signed' in its subfolder, but as long as you have your Extension Manager > Loading policy set to 'Unrestricted' that won't matter.
Does that work ?
