    Delete Used Components
    5 Posts 3 Posters 345 Views 3 Watching
    • Gus RG Offline
      Gus R
      Is there a plugin where I can delete used components? I have a bunch of cabinet pulls and handles I need to delete. I can do it the long way but was just wondering if there's one out there. I'm in the middle of googling that.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        Search for them in Outliner and select/delete?
          Where do you want to delete them from? What do you mean by "used components"? If there are instances of them in the model space but you don't want them, go into the In Model Components panel. Right click on the component's thumbnail and choose Delete. That will remove all instances of the component from the model space. If there are no instances of the components in the model space, open the Details menu (black button to the right of the drop down list field) and click on Purge Unused.
          • Gus RG Offline
            Gus R
            Thanks Rich. I did it the long way. Didn't take long. I looked into outliner which I don't use and found them there. Maybe in the future. Dave, by used I mean existing components. I do use purge unused by I wanted to get rid of a bunch of cabinet pulls.
              Dave R @Gus R
              @Gus-R said in Delete Used Components:
              OK. So you could have used the process I described, right clicking on the component thumbnail and selecting Delete. Would be faster than digging though Outliner, especially if the components are nested in groups or larger components.
