    Cut holes in a steel structure with ProfileBuilder 4
    6 Posts 3 Posters 954 Views 3 Watching
      sentur
      Is it possible to create repeating cut holes in a ProfieBuilder profile? Trying to recreate this attached ref.
      Have created the profile in PB4 without issue. Just the pill-shaped cutouts are trickier to create in a repeating manner.
        I'd used a texture rather than actual geometry.
        Otherwise it needs to be an Assembly where you array it end to end. That wouldn't work for curved paths though.
        S 1 Reply Last reply Reply Quote 0
          sentur @Rich O Brien
          @Rich-O-Brien thank you.
          The profile would only be on straight edge paths.
          How would you achieve it as geometry? It’s likely I’ll need to export geo to another app at some point.
            I'd make this section:
            Then use that to make an Assembly
            https://profilebuilder4sketchup.com/assemblies/
              @Rich-O-Brien thanks
                mperrah Newcomers
                I made this dynamic component that may be useful. Use the size tool to give it a length and the holes resize: https://3dwarehouse.sketchup.com/model/1fd783c4-fbca-43d7-b7c9-9cbb557fa26c/Unistrut-Dynamic-Component?hl=en
                1 Reply Last reply πŸ‘ Reply Quote 1
