    Scene animation with Animator
    107 Posts 3 Posters 25.5k Views 3 Watching
    • ntxdaveN
      ntxdave @fredo6
      @fredo6 said in Scene animation with Animator:
      Can you copy/paste the error message as text from the Ruby Console. The screenshot does not show the head of the error message.
      There was no error message. I now have it working and ffmpeg is installed. πŸ˜€
      Also, always use the positioner (4th toolbar icon) to record the initial position of objects, precisely in case there are issues.
      This is useful for me also. I am going to have several things located in the model so I will capture the camera position for each of the units.
      Press F1...thank me later
      • ntxdaveN
        ntxdave
        Is there a way to adjust the camera position during an animation? As an example, I am going to move an object and I would like to move/change the camera as the movement occurs.
        I know I used to have the camera follow a car as it went through a car was but it has been too long ago and I do not remember how I achieved it. DUH!
        • fredo6F
          Just create as many camera view as you like and place them along the timeline. Animator will interpolate the camera between them.
          • ntxdaveN
            ntxdave
            OK guys I keep going backwards. In the screen short below, I cannot seem to click on the right link to get the timeline back to the left side (like normal). Screenshot 2026-01-02 214025.png
            I am also having a problem trying combine things to make a Clip. I thought you could hit the shift key and click on multiple items to create a Clip.
            • ntxdaveN ntxdave referenced this topic on
            • ntxdaveN
              ntxdave
              What are Kinematic objects and how are they used in SketchUp and Animator?
              What are Trajections and how are they used in Animator?
              What are Visual Effects and how are they used in Animator?
                Rich O Brien Moderator @ntxdave
                @ntxdave said in Scene animation with Animator:
                The buttons you are pointing at are the include/exclude in animation toggles.
                ntxdaveN 1 Reply Last reply
                • ntxdaveN
                  ntxdave @Rich O Brien
                  @Rich-O-Brien Thanks again @rich-o-brien. I can see that I did not look correctly to find these videos.
                  I am not sure I would ever use these features but then, who knows what is in the future. I will set the link up on my laptop for them so that I will not have a problem find them again.
                  I know the video I posted before is not very sophisticated but in the process, I now have a very much better understanding of how to use the combinations and layers/tags in SketchUp with Animator. At least I feel like I am moving forward and will be able to generate some videos with Animator to show a couple of models I am/have been working on.
                  Much of this progress has occurred because of your feedback. πŸ‘ πŸ‘ πŸ‘
                  • ntxdaveN
                    ntxdave
                    Another issue/question. I have not been able to find and instructions/tutorials about how this transition feature works.
                    Yes, I can click on any of the transition types to see what it produces. However,
                    • How would you go back to linear since that is not one of the panels shown?
                    • Can you control the start time and duration of the transition?
                    My goal/objective here is to make a smooth transition from one clip to another. I would kind of like having the clip fade out and the next clip fade in. Is there a way to do that?
                    I have done a little messing around with the camera tools but I also wonder if anyone has any recommendations of which camera options to use. If I add a camera, how do I delete/remove it?
                    • ntxdaveN
                      ntxdave
                      I am having more problems toady. The image below will show 2 problems I am having that I need some help with. The first problem is that I have something that got added to my animation that I do not know what it is and cannot find a way to delete it. The second problem is that I cannot purge items (like unused clips and segments).
                      I also am having a problem getting a camera setting that will make everything show up correctly for all 3 of the clips (right now the clip for the introduction text and its animation (which accidentally got deleted)).
                      Here is a copy of the model so you can look at it and give me some feedback. Animator Learning.skp
                      BTW: On a positive note, I did figure out how to add an image as the background/watermark. I plan to use this capability on a couple of models/animations I am planning on creating/working on. πŸ˜€
                      • ntxdaveN
                        ntxdave @ntxdave
                        The plan for my latest animation projects is to have 3 sections/clips for each project:
                        • Introduction - this section/clip would be an introduction to the animation. Primarily describing what the viewer is going to see in the animation (second clip) and what the project if for.
                        • Animation - This is the main part of the project which is the animation of the SketchUp model. It actually might be made up of a single or multiple clips depending on what the model is all about and what I want the viewer to see.
                        • Conclusion - There might be some projects where this section/clip is not included. However, if there, the purpose would be to provide information about what the viewer just saw and/or give credit to others if necessary.
                        Now, my last question is whether this should all be done in SketchUp using Animator or some other tools or would it be best to just do the animation (with Animator) in SketchUp and use some other tool to create the "full" video. In other words, should the introduction and conclusion be done in SketchUp or are there other tools where you could include the SketchUp animation. For what it is worth, I am using Windows 11.
                          If you intend to have some type of text based elements in your video its probably better suited to another software.
                          You could do it in Animator but I'd offload the non-3D stuff to something else.
                          • ntxdaveN
                            @Rich-O-Brien said in Scene animation with Animator:
                            Any suggestions as to what? What would you use.
                            @rich-o-brien I really need some feedback on the other issues I posted. I am having problems managing some of the elements in my model. In particular, if you look at the previous images I posted, I cannot figure out what that white vertical line is in my timeline and how to edit it. I am also having problems trying to manage the elements.. clips, and views. I have tried to delete some of them but cannot get that to work.
                            You are the only one who has given me any feedback and I am watching videos and looking at other thigs to try to figure this stuff out.
                            • ntxdaveN
                              ntxdave
                              Here is a thread where I have been posting problems/issues I am having with Animator https://community.sketchucation.com/topic/164682/scene-animation-with-animator/36
                              First off, let me say that @rich-o-brien and @fredo05 have been given me some feedback but I still have several issues that I do not seem to be able to resolve.
                              I feel I have learned a lot about using Animator and am close to being able to accomplish what I would like. However, there are several issues that I have pointed out in the other thread that I need some assistance/feedback on. I have looked at several videos and other posts, but I just cannot resolve some issues. If you look at the thread, one of the latest issues I need to address is how to combine some text with an Animation video and what tool you would recommend (I am using Windows 11).
                              Let me also say that if this is a strand post that is viewed as a duplicate of the thread I mentioned above. I am sorry, I am just trying to resolve a few final issues so that I can complete a couple of projects I want to do.
                                I merged that extra thread to here. Creating separate threads pointing to other threads is not helping you.
                                As you have proven, many times already, that if you persevere when you encounter issues you'll figure it out.
                                That bar you are pointing is a scrollbar. Not an element related to the animation. You have Clips starting at 24secs in your timeline than go to 33secs.
                                Regarding your issue Purging. You haven't explained the issue so I can only guess.
                                If you click Purge Unused then Animator will indicate, in Pink, all the unused elements in your file. Then if you click Save Changes and Exit Tool it will remove the Unused Elements.
                                It will not remove elements while you still have the tool active.
                                Lots of these issues you encounter are resolved by A/B testing yourself. If it is not doing what you expect then try a different approach to understand how it is expected to work.
                                So here's a task for you. Get the clips that are way down the timeline to be at the start.
                                See if you can find a way to do it without having to drag the elements individual.
                                HINT: Right click on your timeline.
                                • ntxdaveN
                                  Thanks Rich - I honestly thought it was a mistake to add another thread. I guess it shows that I needed/wanted more feedback.
                                  Thanks again. Yes, even though I have gotten kind of frustrated at time, if I do enough research (especially after some of your responses) I have usually found a solution.
                                  I do not know why I did not see/realize that is what it was. DUH!
                                  Thanks again. I just was not taking the correct steps. I have been able to purge the unwanted stuff and am redoing other items. I had watched one of Fredo6's videos and thought I was taking the right steps. You explanation got the issues resolved for me. I have been able to clean up the info now. It also lead me to going in and changing the names of several segments and clips so now I can look at the list and see what is what.
                                  Done..........another silly error on my part that was partly the result the silly bar that was showing up.
                                  Another DUH! on my part. Another helpful hint.
                                  Now for my last 2 issues (at least at this point):
                                  • I am having problems trying to control the camera so that I get things to show up correctly (at least the way I would like) from one clip to another. I have tried several options but so far have not figured things out the way I would like them. Again, any hints/suggestions would be appreciated. As you have seen, there is a lot of difference between the 2 scenes in my model and I would like for the camera position to change from one of the scenes to the other. I also would like to be able to control the transition from one scenes/clip to another. I haven't figured that one out yet either.
                                  • Yesterday in one of your replies, you suggested using some other software to put together my Animator video and the introduction and conclusion text. While I might want to add some animation to those two sections (which is why I was trying to do it with Animator), you are probably right. Do you have a suggestion of some other software to use? I would prefer a free package but am open to explore suggestions. BTW: Since I have been using Animator for this, I also did some research and found out how to use an image to set the background for my model/animation. I really am looking forward to that for one (and possibly both) of the models/animations I am planning on doing. Neither of them will be all that sophisticated they are just something that I have an inspiration to do and what has lead to all of this hullaballoo.
                                  Once again, I really appreciate your support/feedback.
                                  • ntxdaveN
                                    ntxdave
                                    OK, I just found a video about the camera position in Animator and I am working on it. If I figure this on out correctly I will be very close to where I want to be. πŸ‘
                                      Great, just keep plugging away. There is no better way to learn other than just brute force.
                                      Failing is part of winning.
                                      • ntxdaveN
                                        @Rich-O-Brien πŸ‘
                                        Still wondering about some video editing software
                                          Go research it. But if you keep biting off more and more things to learn you'll get nowhere.
                                          What's the rush? Take things at a sensible pace and enjoy the journey. Make the best animation in SketchUp you can then fuss over the rest when that part is sorted.
                                          • ntxdaveN
                                            ntxdave
                                            OK, I have created a very basic model/animation that has an object that I view via the front, right, left, back, top and bottom. Each of the segments is 2.0 seconds. Not what I would like to do is control the transition from one sequence to the next. However, so far, I have not been able to figure out how to control the transitions,
                                            Here is the silly little model.
                                            Camera Positioning.skp
                                            I probably should also figure out a nice clean way to animate the change from one scene to another. Again, this is really helping me get to the direction I want to go with my future 2 models/animations.
                                            • 2 / 6
