    Box Streching - New Dimensions
    7 Posts 5 Posters 180 Views 5 Watching
      szabo
      Hello, in the Sketchup 2026 version, the tab command, expanding an object with entering exact values, behaves abnormally.
      The tab command responds very poorly, I have to press the button several times before the window for entering dimensions opens.
      Can you please advise me how to fix this problem?
      • fredo6F Offline
        I guess you refer to FredoScale Box Stretching.
        I am not able to reproduce any issue with TAB on Windows and SU2026.
        Can you give more details on your environment. Also, keep the Ruby console open to catch possible errors.
        S 1 Reply Last reply Reply Quote 0
        • Dan RathbunD Offline
          Dan Rathbun
          SketchUp (wisely) does not allow setting TAB as a shortcut accelerator key.
          Using TAB in a tool is likely to clash with OS and application GUI interpretation of the key.
          I'm not here much anymore.
            cesaro36
            Same experience here as @szabo
            After some search and some test i fount that by pressing tab the sketchup window cycles between the gui model, then the side tray, then something else and then back to model. That's why several plugins doesn't behave as expected, previous versions didn't have this behavior.
            I didn't find any solution. So annoying.
              szabo @fredo6
              @fredo6
              Ano jedná se o FredoScale Box Streching. Problémy přesně popsal @cesaro36. Operační systém používám Windows 10.
                J-pags
                I am having trouble with the tab dialog box in 2026 as well. I 2025 it works fine.
                  J-pags
                  update, I can right click on any of the grips that will bring up the tab dialog box, but the tab button shortcut does not work.
