    [Plugin] MatSim (Material Simulation) - v1.7a - 17 Dec 25
    37 Posts 12 Posters 5.7k Views 12 Watching
    • JustinTSEJ
      JustinTSE @fredo6
      Has there been any movement on this issue?
      I'm seeing the same problem when using materials from the Architextures extension. Everything works initially, but if I go back and try to edit the option in the material panel, it looks like this -
      Clicking on any of the themes with the material selected results in the same issue that @jasrode is experiencing.
      fredo6F 1 Reply Last reply
      • fredo6F
        fredo6 @JustinTSE
        @JustinTSE
        I think this is related to some non-alphanumeric characters in the name of materials (like %, =, ...). I need to check the code a see whether there is an impact.
        • _
          _dpdp_ Newcomers @fredo6
          @fredo6 said in [Plugin] MatSim (Material Simulation) - v1.3a - 02 Apr 24:
          If so, this is the issue, as these file need to be transferred. The issue is that te materials are stored in the model if they have been used once in the model, and not purged thereafter.
          They all use a one of two textures. However, they are colorized using the texture settings in the material. Your plugin seemed to store temporary versions of these with each texture being given a unique name by your plugin.
          • fredo6F
            NEW RELEASE: MatSim v1.4a - 31 Dec 24
            Requirements
            • LibFredo6: v14.3a or above
            MatSim 1.4a includes changes for:
            • Extension of validity
            Home Page of MatSim for information and Download.
            Main post of this MatSim thread.
            • B
              Bratthaus
              @fredo6 I'm using the latest version of MatSim with LibFredo6 version 15 (latest) but I'm having a problem when selecting materials. When editing Base or Theme materials sometimes it will let me select a material I've been using and leave it alone but other times when I select a texture it will effectively "colorize" the texture and get rid of the actual photographic picture. In this instance HD Brick and Stone that I've imported and used as a texture.
              • fredo6F
                NEW RELEASE: MatSim v1.5a - 01 Jun 25
                Requirements
                MatSim 1.5a includes changes for:
                • BerserkB
                  Berserk @fredo6
                  @fredo6 The extension is very useful. But in the large model there is a limit on the number of materials supplied, and the color theme change takes a very long time (2 min.) on a modern computer (AMD 16 honest cores up to 5 GHz, 128GB RAM, RTX 2080 Super 12 GB). A model of a city with 80,000 inhabitants. Unfortunately, I can't share the model.2025-07-09 165343.png
                  • fredo6F
                    NEW RELEASE: MatSim v1.5b - 09 Jul 25
                    Requirements
                    MatSim 1.5b includes changes for:
                    • Increased the number of material for simulations to 150 (instead of 50)
                    • fredo6F
                      fredo6 @Berserk
                      @Berserk said in [Plugin] MatSim (Material Simulation) - v1.5b - 09 Jul 25:
                      I released MatSim v1.5b, with up to 150 materials by simulation, instead of 50 (which I already considered a lot).
                      For performance, I am not sure MatSim can do better than what Sketchup would do natively by permuting materials. As for any automated process, just consider how long it would take you to do it manually...
                      • fredo6F
                        NEW RELEASE: MatSim v1.6a - 08 Oct 25
                        Requirements
                        • LibFredo6: v15.5a or above
                        MatSim 1.6a includes changes for:
                        • Bug fixing in relation with licensing
                        • Compatibility SU2026
                        • fredo6F
                          NEW RELEASE: MatSim v1.7a - 17 Dec 25
                          Requirements
                          • LibFredo6: v15.6a or above
                          MatSim 1.7a includes changes for:
                          • 2 / 2
