    [Plugin] MatSim (Material Simulation) - v1.7a - 17 Dec 25
    37 Posts 12 Posters 5.7k Views 12 Watching
    • fredo6F
      @i5963c said:
      Hello, is there any indication on the expected release date of the feature that will allow to assign simulation themes to scenes?
      I have done the Scene part. However, I have problems with the Layout option. Basically, with the current Sketchup and Layout API, it seems impossible to update an existing Layout document from a model.
      I see what I can do to release only the Scene part. I will also include the Default Themes.
      • I
        i5963c Extension Creator
        Hello,
        I get an error message when I launch this plugin, indicating that the version has expired. The error message also refers to the homepage of a plugin that is even not installed on my system (MoveAlignMe).
        I have no clue what's happening...
        Thanks to let me know what needs to be done in order to be able to use the MatSim plugin again.
        Kind regards
        • fredo6F
          NEW RELEASE: MatSim v1.2a - 31 Oct 23
          Requirements
          • LibFredo6: v14.2a or above
          MatSim 1.2a includes
          • Extension of validity
          • Experimental Scene Assignment of simulation
          Home Page of LordOfTheToolbars for information and Download.
          Main post of this LordOfTheToolbars thread.
          • I
            Hello,
            Thanks for the quick reaction and update of the extension (also for TruePaint, which had a similar validity period issue, btw).
            However, I think there is a problem with the MatSim update.
            I installed it on my system, and noticed that it didn't work. When I click one of the two icons or use the equivalent menu options, nothing happens (i.e. the normal dialog boxes don't appear).
            When I activate the Ruby console, there is actually an error, as shown in the screenshot, included in the attached screenshot (Error: #<NameError: unintialized constant F6_MatSim::Bandeau::HTML>).
            This error occurs with a SketchUp model for which I applied the initial version of the MatSim plugin already before. I noticed that when I try to use the new version of the MatSim plugin on a new SketchUp model or on a model that hasn't already MatSim settings applied, the error initially doesn't appear, and asks whether you want to create a material simulation. However, afterwards, the error also happens for these files (i.e. actually nothing happens when clicking the buttons). For each click on a button, the same series of messages is added in the Ruby console.
            So, it looks like there is a problem with backward compatibility, so I'm stuck for the moment.
            In my current model, I rely heavily on the MatSim features (i.e. I applied different coloring schemes to emphasize different model components in different scenes). For the time being, I needed to manually select the appropriate simulation settings for the scenes, so the announced link between MatSim settings and scenes would be a big timesaver for my use case.
            However, now I even can't access the MatSim settings anymore, which makes my setup completely 'useless'.
            As a 'quick fix', can I therefore suggest to release an intermediate version that just includes the update for extending the validity period (unless of course if the root cause of the current problem can easily be fixed).
            Thanks a lot in advance.
            Kind regards.
            • fredo6F
              NEW RELEASE: MatSim v1.2b - 31 Oct 23
              Note that MatSim 1.2a has a bug. So please upgrade to v1.2b.
              Requirements
              MatSim 1.2b includes
              • Experimental Filters by Theme for materials which are not explicitely assigned an alternate material
              I will need to document and make a tutorial for the two features above however.
              Home Page of MatSim for information and Download.
              Main post of this MatSim thread.
              • fredo6F
                NEW RELEASE: MatSim v1.3a - 02 Apr 24
                Requirements
                • LibFredo6: v14.3a or above
                MatSim 1.3a includes changes for:
                • Future compatibility
                • _
                  _dpdp_ Newcomers
                  We are desperately trying to move our mat sim we created in the office for a customer from our office desktop to a laptop for remote presentation. Any materials containing textures will not have textures applied. Only colors are carried over. On initial load, the material looks correct, but as soon as you change to another color scheme, the textures disappear.
                  • fredo6F
                    Are you copying the skp file from one machine to another one?
                    And if so, do you see the textures in the Material browser?
                    _ 1 Reply Last reply
                    • _
                      _dpdp_ Newcomers @fredo6
                      @fredo6 Yes we're opening the skp file of our design on a different machine than the mat sims were set up on. On this laptop, the textures don't appear in the material previews. When you edit the material, the "Use texture image" is unchecked and the image file field is blank. As I said, this is only after selecting a different theme. On load, the initial material is shown correctly and the properties in the edit tab are correct.
                      fredo6F 1 Reply Last reply
                      • fredo6F
                        fredo6 @_dpdp_
                        @_dpdp_
                        Do you use custom textures, based on your PNG files?
                        If so, this is the issue, as these file need to be transferred. The issue is that the materials are stored in the model if they have been used once in the model, and not purged thereafter.
                          jasrode
                          I recently discovered the same issue and created a simple example to demonstrate.
                          The simulation was created on my intel iMac using Sketchup 2024. I did not use any custom textures, only the textures that come with SketchUp. Switching from the BASE to Theme A worked perfectly.
                          I opened the file on my PC Running Window 10 and SketchUp 2024. The initial appearance is correct before activating MatSim.
                          The image below is an example of how the textures appear after MatSim is activated. Notice only the water texture is not in the BASE column and its appearance remains correct.MatSim_test1.jpg
                          I duplicated the SketchUp file on the iMac and added the water texture to the BASE column. Below is the example from the PC after MatSim was activated. Based on my test, if a texture is within the BASE column, it will not appear correctly.
                          I tested the Sketchup files on a different iMac and had the same issues as the PC.
                          • fredo6F
                            fredo6 @jasrode
                            @jasrode
                            It might be a fundamental issue in MatSim.
                            I need to check
                            JustinTSEJ 1 Reply Last reply
                            • JustinTSEJ
                              JustinTSE @fredo6
                              Has there been any movement on this issue?
                              I'm seeing the same problem when using materials from the Architextures extension. Everything works initially, but if I go back and try to edit the option in the material panel, it looks like this -
                              Clicking on any of the themes with the material selected results in the same issue that @jasrode is experiencing.
                              • fredo6F
                                fredo6 @JustinTSE
                                @JustinTSE
                                I think this is related to some non-alphanumeric characters in the name of materials (like %, =, ...). I need to check the code a see whether there is an impact.
                                • _
                                  @fredo6 said in [Plugin] MatSim (Material Simulation) - v1.3a - 02 Apr 24:
                                  If so, this is the issue, as these file need to be transferred. The issue is that te materials are stored in the model if they have been used once in the model, and not purged thereafter.
                                  They all use a one of two textures. However, they are colorized using the texture settings in the material. Your plugin seemed to store temporary versions of these with each texture being given a unique name by your plugin.
                                  • fredo6F
                                    NEW RELEASE: MatSim v1.4a - 31 Dec 24
                                    Requirements
                                    MatSim 1.4a includes changes for:
                                    • B
                                      Bratthaus
                                      @fredo6 I'm using the latest version of MatSim with LibFredo6 version 15 (latest) but I'm having a problem when selecting materials. When editing Base or Theme materials sometimes it will let me select a material I've been using and leave it alone but other times when I select a texture it will effectively "colorize" the texture and get rid of the actual photographic picture. In this instance HD Brick and Stone that I've imported and used as a texture.
                                      • fredo6F
                                        NEW RELEASE: MatSim v1.5a - 01 Jun 25
                                        Requirements
                                        MatSim 1.5a includes changes for:
                                        • BerserkB
                                          Berserk @fredo6
                                          @fredo6 The extension is very useful. But in the large model there is a limit on the number of materials supplied, and the color theme change takes a very long time (2 min.) on a modern computer (AMD 16 honest cores up to 5 GHz, 128GB RAM, RTX 2080 Super 12 GB). A model of a city with 80,000 inhabitants. Unfortunately, I can't share the model.2025-07-09 165343.png
                                          • fredo6F
                                            NEW RELEASE: MatSim v1.5b - 09 Jul 25
                                            Requirements
                                            MatSim 1.5b includes changes for:
                                            • Increased the number of material for simulations to 150 (instead of 50)
                                            • 2 / 2
