    Fredo6 Round Corner Crash Sketchup
    28 Posts 6 Posters 4.3k Views 6 Watching
      DoCelikkol
      Sketchup 2025 - Its Crashing with very basic step
      Dave RD 1 Reply Last reply Reply Quote 1
        Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
        D 1 Reply Last reply Reply Quote 0
          Dave R @DoCelikkol
          @DoCelikkol what version of SketchUp? What's the radius of the round over? Your GIF leaves out important information.
            DoCelikkol @Rich O Brien
            @Rich-O-Brien
            Fredo6 Plugins Information on 2025-09-19 16:46:16 +0300
            • Sketchup: 25.0.660
            • LibFredo6: v15.4e
            • LibFredo6 Binary loaded
            • Sketchucation ExtensionStore: 4.4.1
            • SCFLicense: v6.4a - 74
            • Fredo6 Plugins
              Curviloft v2.0a - licensed FULL
              Curvizard v2.5a
              FredoScale v3.6a - licensed FULL
              FredoTools v4.5c
              JointPushPull v4.9a - licensed FULL
              RoundCorner v3.4a - licensed FULL
              ToolsOnSurface v2.6a - licensed FULL
              TopoShaper v2.7a
              VisuHole v1.5a
              Signature File: 2025-08-25 11:45:40 +0300
              Curviloft: 2025-08-25 11:45:46 +0300
              FredoScale: 2025-08-25 11:46:16 +0300
              JointPushPull: 2025-08-25 11:46:26 +0300
              RoundCorner: 2025-09-18 14:26:29 +0300
              ToolsOnSurface: 2025-08-25 11:46:45 +0300
              DoCelikkol @Dave R
              @Dave-R
              And Sketchup version is
              Sketchup 2025 - Version 25.0.660 64-bit
                @DoCelikkol
                I can't reproduce your instant hard crash.
                  @Rich-O-Brien
                  I'm having the same issue with clean, empty Sketchup pages. I've checked all the Plugin updates with Fredo's own Update Checker. There's no problem. What's your Sketchup version?
                    2025, You might have a clash of some sort. Probably best to disable stuff and see if it resolves
                      What graphics card? Which graphic engine is selected?
                        DoCelikkol @Dave R
                        @Dave-R
                        RTX 4060 - Studio Driver
                          @Rich-O-Brien
                          Hmm I need to check. Thanks for your suggestion.
                            You could try switching to the classic graphics engine and see what happens.
                            Also make sure you have the latest graphics drivers from nVidia.
                              DoCelikkol @Dave R
                              @Dave-R
                              Still same. Instant Crash
                              • fredo6F Offline
                                Does it happen when you use RoundCorner on any shape or just this one ?
                                Can you try JointPushPull or FredoScale to see if the crash also happens.
                                Do you get a bug splat or a crash without bugsplat?
                                D 2 Replies Last reply Reply Quote 0
                                  DoCelikkol @fredo6
                                  @fredo6
                                  PushPull also crashes in some shapes. But I'm talking about complex shapes. For example its produce shape but when I click or return to exit Its crash
                                  For Example, the ones I shared below do not crash. RoundCorner
                                  But the ones I shared below gives crash.
                                    DoCelikkol @fredo6
                                    @fredo6
                                    And there is no bugsplat. Completely Instant crash and empty screen.
                                      khanhafeez
                                      me also same issue facing from last 4 month still no solution find
                                      • fredo6F Offline
                                        Did you try to switch to the classic engine?
                                          DoCelikkol @fredo6
                                          @fredo6
                                          Yes, I tried. I have another computer with an RTX 4080 Super graphics card. All drivers are up to date. Processor, RAM, graphics cards, etc., and all extensions are up to date. I couldn't find a solution. I uninstalled and reinstalled SKetchup to try it out. I re-added all extensions and their licenses. No solution.
                                          • fredo6F Offline
                                            Did you siwtch to the Classic Graphic engine on any of your PCs?
                                            By the way, you don't need to reinstall Sketchup, it's probably not related.
