    WIP - Kitchen
    22 Posts 4 Posters 3.6k Views 4 Watching
    • L
      L i am @Gus R
      • Gus RG
        Gus R
        Thanks guys!
        Bedroom. Needs more work but I did start this morning.
        Dresser looks too red. 😊
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • Gus RG
          Gus R
          Thanks guys!
          Bedroom. Dresser looks too red. Started this morning.
          • Gus RG
            Gus R
            A little warmer with some curtains and other details.
              Better and more inviting, thanks for the inspiration it is always helpful.
                • Gus RG
                  Gus R
                  Thanks Mike.
                  Other side of the bedroom.
                  • Gus RG
                    Gus R
                    Side view of the bedroom using D5's section.
                      The only area I can see to alter is the fire in the 'place. It is obviously a 2d graphic. If it is painted into a component, try adding several at different angle and see if a certain degree of 'normal' or bump can be added. I will see if it can be done with what I have. Twilight used to manage OK.
                      Otherwise, you still rock.
                      Gus RG 1 Reply Last reply
                      • Gus RG
                        Gus R @Mike Amos
                        @Mike-Amos
                        It's a 3d D5 Render "particle" that's animated.
                        Gus Robatto Bedroom WIP 05.mp4
                        I replaced it with a smaller one.
                        Added some more bells and whistles.
                        Mike AmosM 1 Reply Last reply
                          Mike Amos @Gus R
                          @Gus-R
                          Thanks for the explanation, looks great.
                          • 2 / 2
