    Another Steam Engine
    71 Posts 16 Posters 4.9k Views 16 Watching
      Cooking on gas. πŸ‘
        Thank you folks and HNY.
        https://live.staticflickr.com/65535/52598503374_85a554f161_k.jpg
        • Bryan KB Offline
          Excellent as always!
            https://live.staticflickr.com/65535/52612162028_65793e94e5_k.jpg
            This is a little Stirling engine. The flywheel is 49mm in diameter.
            • Bryan KB Offline
              Very cool. πŸ‘
                Another cracking piece you have there. πŸ‘ πŸ‘
                • ely862meE Offline
                  ely862me
                  Fantastic! Indeed some of these would deserve to be printed and hanged in some industrial based interior designs!
                  Elisei (sketchupper)
                  Come and See EliseiDesign
                    Dave, you could make some decent money selling these as card/paper models. Flattery etc can help but check out https://www.papermodelers.com/forum/railway-related-builds/ , the railway type would seem closest to your steam engines.
                      bexar
                      Dave,
                      Very nice work, I am very impressed. I have been "modeling" for a short time and now would like to dip my toe into steam engine "animation". I saw your video of the Muncaster "automation". Another "home run".
                      I have tinkered with MS Physics a bit, I really haven't got my head wrapped around the tool' methodology. I was wondering which animation tool did you used on the Muncaster (Ms Physics, Animator, Key Frame or other)??
                      Again, nice work on all of your models.
                      bexar
                      Southeast Queensland
                        Dave R @bexar
                        @bexar thank you.
                        My animations of the various steam engine models were done without using any "animation tools". I just use copies of components, tag visibility, scenes, and the native animation export option straight out of SketchUp. For me that's straightforward and simple.
                          bexar
                          WOW! Can you direct me to resources (youtube, pdf, etc) that explains that process that you use? Now, I'm even more impressed by your skill set!!! Have a good day!!
                            Thanks! There's really not a lot to it. I make multiple copies of the components along their route of travel. There's a different tag applied to each of the copies and then a different one of those tags is visible for each scene. This screen shot shows a simpler engine model with four of the 24 tags turned on. There are 24 scenes for the animation.
                            It gets a little more complicated with an engine like the horizontal Muncaster because of the steam valve and the linkages.
                            Here's the resulting animation:
                            https://flic.kr/p/2n7xvyh
                            majidM 1 Reply Last reply Reply Quote 1
                              bexar
                              Thank you so much for that information. I'll certainly do a bit of self-education. The animation was just so smooth! Thank you so much for your helpful reply!
                                Dave R @bexar
                                @bexar you're welcome.
                                FWIW these engine animations are exported with no transitions between scenes so there are only as many frames as scenes. Then in a video editor I just copy and paste the animation to create a repeating sequence.
                                  1 Reply Last reply Reply Quote 5
                                    Clean modelling. You going to 3D print these?
                                      Dave R @Rich O Brien
                                      @Rich-O-Brien thank you. I don't know. It hink I'd be disappointed in the results.
                                      • majidM Offline
                                        majid @Dave R
                                        @Dave-R this is crazy! Pure Sketchup! You are leveling up the SketchUP!
                                          Dave R @majid
                                          @majid thank you. Are you referring to the animations I posted?
                                          • 4 / 4
