    Toposhaper Issue
    13 Posts 5 Posters 456 Views 5 Watching
    • pkbrooksP Offline
      pkbrooks
      Working with Toposhaper in SKU 2024 & 2025.
      Have latest updated LibFredo6 15.4a and last version of Toposhaper 2.7a.
      Im working on a M1 MacBook Pro with Sonoma 14.5
      The UI doesn't look at all like Im seeing in all the images and Im getting errors about cleansing that I don't understand.
      I have watched a few videos now on YT and im just not getting the same experience that the video shows. I have tried in 24 & 25 and both have the same issue.
        Sometimes sharing the file will help yield more concise info on what the issue could be.
          rv1974
          use tt edge tools to clean the linework
          • pkbrooksP Offline
            pkbrooks
            Thanks @rv1974. Will try that and if don't get a good result and I will post the file.
            • fredo6F Offline
              The issue is that you launch TopoShaper from within the group.
              The best is to just select the group from outside and launch TopoShaper.
              • pkbrooksP Offline
                pkbrooks
                @fredo6 I have the topo lines in a group and that is inside another group. If Im inside the mother group and laugh topo will I get the error?
                • fredo6F Offline
                  It's always better to launch TopoShaper by selecting the group from outside. In your case, the issue is related to a Tag / Layer assigned to the curves which is also the active Tag.
                  panixiaP 1 Reply Last reply Reply Quote 0
                  • pkbrooksP Offline
                    pkbrooks
                    Update:
                    @fredo6 - Tag issue was it. Was given the file from an architect and thought I had caught all the issues. This last group didn't get the geometry tag reset to "Untagged". As soon as I did that. Tool worked. Thanks!
                    • panixiaP Offline
                      panixia @fredo6
                      @fredo6 said in Toposhaper Issue:
                      Intersting.
                      Never noticed that.
                      Honestly I never encounter this kind of problems.
                      Maybe it's because I always have my actual loose geometry on layer 0?
                      Or just luck?
                      pkbrooksP 1 Reply Last reply Reply Quote 0
                      • fredo6F Offline
                        Does it work now?
                        • pkbrooksP Offline
                          pkbrooks @panixia
                          @panixia
                          Normally that is my workflow as well. Everything goes to "Untagged".
                          In this case, I got a .dwg site plan with all kinds of information and the existing tags were the only way for me to know what was what.
                          So I was picking each tag, selecting the geometry, re-tagging it to "Untagged" and then grouping it and putting it on my own tag system.
                          There was a 2d topo map that I did convert but they also provided an elevation accurate set of topo lines that forgot to process. I just grouped it and then went straight to toposhaper. I was in a rush I think.
                          That group was also inside another group. Solution was as @fredo6 said, put the group by itself, fixed the geometry tagging and then run the tool. Have a nice healthy terrain now.
                          panixiaP 1 Reply Last reply Reply Quote 1
                          • panixiaP Offline
                            panixia @pkbrooks
                            @pkbrooks said in Toposhaper Issue:
                            Next time you may want to try the "Cleanup" plugin by Thomthom.
                            It has a one click "geometry to layer 0" feature which is perfect for such situations.
                            You just select the whole model (or the imported cad), run it and it will put all the geometry (not group and components) on layer 0 at once..
                            • pkbrooksP Offline
                              pkbrooks
                              Actually a better plugin for someone who writes plugins would be a UI that shows all current .dwg layers and next to each layer is a tag selection box. this would allow me to move thru reassignments with ease. But even better would be that every piece of geometry then gets grouped and tagged with the new SKU tag and the geometry within is assigned to "untagged".
