    [Deprecated]Sketchucation Tools 4.4.1
    60 Posts 18 Posters 8.8k Views 17 Watching
      Jerome_971 @Jerome_971
      After more investigations and a lot of readings on internet to understand how it works... I think there is a problem with CSS rules. SU Make 2017 cannot 'read' them. I don't know I can say it in this way (I don't have coding skills and Im a french speaker).
      If SU Make 2017 was able to use Chrome for embedded browser I think it will work.
      TIGT 1 Reply Last reply
        TIG Moderator @Jerome_971
        @Jerome_971
        But v2017 does use the built-in Chrome browser with any HtmlDialogs [like the ExtensionStore's]
        • T
          teppi_edmund
          I have the problem that sketchUp will quit itself after pressing Manage License or SCFLicense: Global Status, I have try reinstall SU2024 to 2021 with different SketchUcation version still got same result, anyone solve this issue before?
            Miss Lazy Newcomers
            Hello
            Yesterday I installed this version and I am unable to sign in with my user credentials. the error msg is "Could not authenticate User"
            Rich O BrienR TIGT 2 Replies Last reply
              Rich O Brien Moderator @Miss Lazy
              @Miss-Lazy
              Login requires a username not an email address. Please ensure you are logging in using a username.
                TIG Moderator @Miss Lazy
                @Miss-Lazy
                And also that your member-name is written exactly as in the tag above... but perhaps with a <space> instead of the hyphen - ?
                  Miss Lazy Newcomers
                  @Rich-O-Brien I am using my user name not my email address.
                  @TIG my user name without hyphen, but here its showing with hyphen, I will try to login using a hyphen. thanks for the help.
                    DB63 Newcomers
                    Salve a tutti, non riesco ad installare il plugin in SU 25
                      Rich O Brien Moderator @DB63
                      @DB63 said in Sketchucation Tools 4.4.1:
                      Extensions > Extension Manager > Install
                        Macron282 Newcomers
                        Is there a release for sketchucation tools to be compatible with Sketch up 2025?
                          Rich O Brien Moderator @Macron282
                          @Macron282 said in Sketchucation Tools 4.4.1:
                          Sketchucation Tools | SketchUcation
                          (sketchucation.com)
                          v4.4.1 is compatible
                          • Rich O BrienR Rich O Brien unpinned this topic on
                          • 3 / 3
