    Post diagnosis.
    72 Posts 5 Posters 4.0k Views 5 Watching
      pixelcruncher Extension Creator @Mike Amos
      @Mike-Amos said in Post diagnosis.:
      Movement?
      Twilight.
      Rayscaper.
      Something wonky, the 0/0 samples/px doesn't look good. It seems like it never started rendering. What happens if you switch to CPU rendering as a test?
      • Menu > File > Settings...
      • Tick off the "Use GPU Rendering"
        I have already ticked 'use gpu rendering' a while ago when the system was changed.
          Hey Mike,
          I just wanted to check if the model renders correctly with the CPU and try to isolate the problem to GPU rendering.
          It does render for me using GPU rendering; the model is surprisingly polygon-heavy. I do see the same problem with the flames texture and the alpha channel:
          I guess you are using the same flames texture in Twilight Render. I'm surprised it gives such a nice result because this flame texture doesn't have a clean alpha channel. There's a pattern in the alpha channel:
          Does Twilight Render have a way to display thumbnails for textures? I'm intrigued at how it can render this so cleanly.
          Cheers,
          Thomas
            Mike Amos @pixelcruncher
            @pixelcruncher
            I spotted the alpha chanel stuff earlier when attemping to use that =texture for the log fire in the cold view scene. Weird.
            Transparency png are flaky tbh and I am looking to 'try' with 3d flames, I shall need a lot of paracetamol for that though.
            No idea if Twilight has any fanciness in this respect, Fletch and Chris are now gone so, relying on my daffy memory which is seive quality.
            I have notice that having a backgrounbd which has some commonality to the transparency helps. The red/scarlet works best here.
            I have attempted to recreate a scene with cutaway and limiting nayural light to that provided by the geometry, windows etc. Many splats with no report just the windows desktop.
            I shall leave this here, needs a lot of adjustemnt lighting levels wise but gives a reasonable render potential.
            The semi opaque walls, not so sure about.
              Mike Amos @Mike Amos
              Adjustment.
                OK, finally got the onboard graphics online, adopted the classic engine in Sketchup and rebooted. Produced an immediate error in windows which I hope is a transient.
                I think there is an improvement in this image, same view and same render time but 'feels' better. Opinions?
                  When you mention onboard are you referring to integrated graphics in a CPU like Intel UHD? Or is this onboard the GPU?
                  I'd be concerned by the 'immediate error' as that suggest conflict.
                    Mike Amos @Rich O Brien
                    @Rich-O-Brien
                    Sorry, I do not think the graphics are the issue.
                    Something about megascans when I restarted Sketchup after making the changes in BIOS.
                    I am seeing a thirty second or more delay when selecting, painting a surface or importing an object which is something I have been seeing anyway. SKetchcup can take a minute or more to load to the welcom screen and then open a model even one saved to the OS drive.
                    Having said that, I sometimes get a onedrive saving error "Cannot save, this file is already in use by another user", this turns out to be a one drive folder in my microsnot account. These two renders were consecutive and I have no clue. The bonus is that in true architect fashion, the second render does bring the garden "Indoors"......
                      BTW, onedrive was deleted after being deactivated.
                        Well, that vanishing trick with walls/floors has not repeated.
                        Close to the intent with this.
                          Exterior view.
                          • tuna1957T Offline
                            tuna1957
                            Interesting design. Keep after it. πŸ‘
                              Ta, looking to different textures and lighting schemes.
                              The crazy cat motif is there to demonstrate a dialectic glass effect which may take experimentation. As will the interior walls set to glass.
                                Thinking some on that but digressing to automotive. I may have mentioned that I like this hotrod.
                                Just a bit closer to what I am aiming at.
                                  For petrol heads, this issue has some good reading. https://porschecarshistory.com/wp-content/old/lib/magazines/RR/Rolls-Royce a Bentley Driver β€” Issue 3 2017.pdf
                                    Is this Rayscaper or Twilight?
                                      Posted in wrong thread, sorry. Twilight.
                                        Actually, not the wrong thread at all, I just missed stating which render program.
                                        • 4 / 4
