    Orgelf's works. second topic.
    765 Posts 28 Posters 616.5k Views 28 Watching
    • orgelfO
      orgelf
      Altar, second project.
      Simpler, more conceptual.
      The chalice is a simple bowl collecting amniotic water. It is placed on a incense nest.
      The stones of the altar and those on the fences -uterine by is balanced.
      The two large branches are also downloaded models and are also incense.
      The nun is a downloaded model to which I added two personal illustrations to texture them.
      I actually didn't used Sketchup for this one but I still post it here. Tell me if I should supress this post.
      the website https://notredame2.weebly.com
      In greater on these links
      https://zupimages.net/up/25/08/ktmf.jpg
      https://zupimages.net/up/25/08/7m72.jpg
      https://zupimages.net/up/25/08/jns2.jpg
      https://zupimages.net/up/25/08/qyq3.jpg
      https://zupimages.net/up/25/08/prty.jpg
      https://zupimages.net/up/25/08/3k74.jpg
      https://zupimages.net/up/25/08/vuah.jpg
      https://zupimages.net/up/25/08/zx44.jpg
      https://zupimages.net/up/25/08/p5bj.jpg
      https://zupimages.net/up/25/08/ufkx.jpg
      https://zupimages.net/up/25/08/h542.jpg
      http://www.orgelf.com
        Truly gob smacking. Tres magnifique.
        • orgelfO
          orgelf
          Merci bien mister Amos. πŸ‘ πŸ‘
          Third altar concept. On the theme of the frog as a symbol of the matrix, fertility and birth (water to earth).
          The headdress symbolizes the matrix and the moon. The cape seems to be made up of eggs.
          The frog was carved with Nomad/iPad.
          The character is a downloaded model to which I just changed the texture of the dress.
          in greater on these links
          https://zupimages.net/up/25/08/u7bd.jpg
          https://zupimages.net/up/25/08/nzwy.jpg
          https://zupimages.net/up/25/08/87uy.jpg
          https://zupimages.net/up/25/08/jyte.jpg
          https://zupimages.net/up/25/08/65no.jpg
          https://zupimages.net/up/25/08/1ne7.jpg
          https://zupimages.net/up/25/08/jmyi.jpg
          https://zupimages.net/up/25/08/m2e6.jpg
          https://zupimages.net/up/25/08/08u5.jpg
          https://zupimages.net/up/25/08/ulwj.jpg
          https://zupimages.net/up/25/08/4rzp.jpg
          https://zupimages.net/up/25/08/jzph.jpg
            Wow.that frog texture is so nice. SSS too?
            tuna1957T 1 Reply Last reply
            • tuna1957T
              tuna1957 @Rich O Brien
              @Rich-O-Brien said in Orgelf's works. second topic.:
              Agree 100% with Rich πŸ‘
              • orgelfO
                orgelf
                thanks . Yes the shader is a mix between two marble shaders , one with sss , one without sss, based on AO. The sss is in the hollows.
                • L
                  You are a true artist, and I do not say that lightly
                    I agree, one of my top places to visit on Sketchucation.
                    • orgelfO
                      orgelf
                      @L i am droit au coeur , as we say in french. Thanks a lot 🀠
                      @Mike Amos . You are so welcome here πŸ™
                      Another altar project.
                      The official is a machine with a child's head (downloaded model). The chalice always takes up the idea of ​​amniotic fluid.
                      The beam that delimits the altar place is also incense. The idea of ​​the circle takes up the idea of ​​the pregnant belly, the matrix. The incense cubes have a meaning according to their arrangement in the enclosure. The robot's hands and feet are downloaded models.
                      The 'pedestal' takes up the idea of ​​cells that agglutinate to form a body.
                      https://zupimages.net/up/25/09/m1i3.jpg
                      https://zupimages.net/up/25/09/2zlm.jpg
                      https://zupimages.net/up/25/09/xka9.jpg
                      https://zupimages.net/up/25/09/ghn7.jpg
                      https://zupimages.net/up/25/09/6lur.jpg
                      https://zupimages.net/up/25/09/kzs2.jpg
                      https://zupimages.net/up/25/09/63qh.jpg
                      https://zupimages.net/up/25/09/rhch.jpg
                      https://zupimages.net/up/25/09/9660.jpg
                      https://zupimages.net/up/25/09/isq3.jpg
                      https://zupimages.net/up/25/09/100h.jpg
                      https://zupimages.net/up/25/09/k34p.jpg
                      https://zupimages.net/up/25/09/sjks.jpg
                      https://zupimages.net/up/25/09/oxwx.jpg
                      https://zupimages.net/up/25/09/y3vo.jpg
                      https://zupimages.net/up/25/09/ivqr.jpg
                      https://zupimages.net/up/25/09/idoo.jpg
                      • orgelfO
                        orgelf
                        Last 3D project, still related to the interior of the cathedral dedicated to the Virgin at the end of her pregnancy. I had the idea of ​​an illustration of the Virgin opening her belly like a window and revealing Christ to humanity. Being a little in the vagueness as to the composition etc I asked an AI to generate images-ideas. I started from one of the proposals (last image) for this work. What I particularly appreciated in the AI ​​proposition is that we could interpret the image as a 3D/2D mixture, what I did.
                        The illustration of the Virgin herself was carried out with Procreate/iPad.
                        Body of the christ made with Makehuman. Head sculpted with Nomad.Ipad.
                        I also integrated 3D scans from low reliefs in the upper corners.
                        I put some pictures of white so that we can better realize 3D.
                        https://zupimages.net/up/25/10/qoj0.jpg
                        https://zupimages.net/up/25/10/9o31.jpg
                        https://zupimages.net/up/25/10/ca3y.jpg
                        • tuna1957T
                          tuna1957
                          No end to the depths of your imagination. πŸ‘πŸ‘
                          L 1 Reply Last reply
                          • L
                            L i am @tuna1957
                            @tuna1957 said in Orgelf's works. second topic.:
                            Agreed
                              Me three.
                              • orgelfO
                                orgelf
                                That's very nice guys...thanks.
                                I just walk my path.
                                'The Luster-Forceps' Last altar for my version of Notre Dame dedicated to the Virgin at the end of pregnancy.
                                Face and hands are a downloaded model.
                                Ditto for the costume model where I only took care of textures and shading (material).
                                No Sketchup on this one but I still post it here is that's ok.
                                You can download the images in large size on this link.
                                https://www.mediafire.com/.../ok3g.../lustreforceps.zip/file
                                • orgelfO
                                  orgelf
                                  'Baby Jesus'. Smartphone multi -fittings concept available in places of worship. The smartphone is dissociated with the base once unlocked.
                                  There is a parallel between the umbilical cord and a wired charger.
                                  Sculpted with Nomad/iPad.
                                  The body comes from Makehuman.
                                  The halo was modeled with sketchup.
                                  https://zupimages.net/up/25/12/n311.jpg
                                  https://zupimages.net/up/25/12/ajbg.jpg
                                  https://zupimages.net/up/25/12/7z4t.jpg
                                  https://zupimages.net/up/25/12/j6bi.jpg
                                  https://zupimages.net/up/25/12/971u.jpg
                                  https://zupimages.net/up/25/12/gll8.jpg
                                  https://zupimages.net/up/25/12/kopz.jpg
                                  https://zupimages.net/up/25/12/xago.jpg
                                  Mike AmosM 1 Reply Last reply
                                    Mike Amos @orgelf
                                    @orgelf
                                    Thanks mate. Brilliant.
                                      I love your output. It’s pure thought to creation.
                                      • L
                                        Jus amazing work, what is your workflow and does it involve AI?
                                        • L
                                          L i am @orgelf
                                          @orgelf Hey mate I have sen a link to Australian music artists. If you watch the vid I think the graphic will be very appreciated by you. The music is as ground breaking as the imagery "PNAU" they also directed the song by Cold Heart - Elton John & Dua Lipa. Every time I listen to them genius come to mind. Stunning graphics
                                          https://www.youtube.com/watch?v=OeawokXyvXY
                                          https://www.youtube.com/watch?v=OLzQX8OIWhghttps://www.youtube.com/watch?v=sIfTD2i50s8
                                          • orgelfO
                                            orgelf
                                            @Mike-Amos yes, quite shiny. 😊
                                            @L-i-am thanks a lot
                                            I watched the videos . The bodypaint is very interesting. I am not very into this kind of music, I prefer stuff like Swans ou Godspeed You Black Emperor. But the visuals are good. πŸ‘ πŸ‘
                                            Reliquary concept for the amniotic fluid of the Virgin.
                                            The idea is that at the time of the loss of water, God did not allow them to touch the soil but that they remain in levitation in order to be recovered.
                                            Bigger size here
                                            https://zupimages.net/up/25/12/efut.jpg
                                            https://zupimages.net/up/25/12/54mc.jpg
                                            https://zupimages.net/up/25/12/yx0j.jpg
                                            tuna1957T Mike AmosM 2 Replies Last reply
                                            Reply Quote 2
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 38
                                            • 39
                                            • 33 / 39
