    Box Exercise Discussions
    44 Posts 4 Posters 6.9k Views 4 Watching
    • ntxdaveN
      ntxdave
      I am having a problem learning how to use one of Box's examples.
      Here is my model: Box Practice 1.skp
      Press F1...thank me later
      • ntxdaveN
        ntxdave @tuna1957
        @tuna1957 Very well done sir. 👍👍👍
        I need to go watch more of Box’s video and learn how to do something like this. 😁
        tuna1957T 1 Reply Last reply
        • BoxB
          Box @ntxdave
          @ntxdave said in I’ve Been “Boxed”:
          I do have a little problem with in the videos is that he obviously enters info in the text boxes that you cannot see in the video.
          I'm not sure what you mean by this, I go out of my way to show everything I can in my gifs, which is why I use a toolbar rather than keyboard shortcuts, and that toolbar has the text box included that shows everything I type. Very occasionally something might be just off screen, but I usually mention what it is if that is the case.
          Can you link to one that you are having an issue with.
          ntxdaveN 2 Replies Last reply
          • ntxdaveN
            ntxdave @Box
            @Box I apologize Box. I just went and watched the gif again and somehow I messed the text entries before. I am very embarrassed. 😖
            • ntxdaveN
              ntxdave @Box
              @Box said in I’ve Been “Boxed”:
              Here is a link to the gif I have been having some problems with..
              link text
              • Apparently, I am not not drawing the arc between to circle correctly. I wind up with some connections that are not as clean as the should be. After i draw the five sides, I have to use the TIG Weld feature to connect the lines so I can use them for the path for the Follow Me tool.
              • Once I have created the design using the step above, I then cannot delete the inside faces. When I do get it to work, I get the outline in the face and I have to go erase the outline.
              • I do not have a problem with the "bottom" part of the design.
              • Then, I wanted to try something a little different from your design. I wanted to create a whole through the top item that matches the bottom part of the design. Again, I had some problems trying to cut a hole in the top part.
              All of this is my first item in your excellent set of topics. After I get some more experience, I want to learn hor to create some of the things others have posted in this thread. In particular, I would like to learn how to create something like the lamps with the items around them (do no know the correct term to use).
              Again, I want to thank you for sharing the items in your thread. They are very useful, and I want to expand my capabilities. 😀
              BTW: Here is the file from what I did for this exercise: Box Practice 1.skp
              BoxB 1 Reply Last reply
              • BoxB
                Box @ntxdave
                Make sure you get the magenta inference. The start and end points of the arc should be in the same relative segments of the circles. Often best to use a segment Midpoint rather than an endpoint. And it needs to be at a point that will flow smoothly with the circle.
                Well yes, but all I did was triple click to select all of it as the path. Weld allows you to select it with one click.
                I double click on the face, which selects the face and it's edges allowing it all to delete in one go.
                Looking at your model it is clear you haven't connected the arc smoothly.
                And the circle you have in the middle of the shape is drawn Off Axis, so it will not line up correctly with the rest of the model.
                ntxdaveN 1 Reply Last reply
                • ntxdaveN
                  ntxdave
                  Thanks for the response/repoy. Hopefully I will be able to try again later today. Again, I really appreciate you giving me instructions in how to get this wright. Eventually I want to be able to draw things like the first picture in you thread. Be I need to hone my skills first. 😁
                  • ntxdaveN
                    ntxdave @Box
                    I am still having a problem with connecting the circles. Do you have a suggestion/advice about how to correctly connect the circles? How do I get a reference to the segment Midpoint?
                    • BoxB
                      Look for the tooltips that tell you midpoint or end point etc
                      • ntxdaveN
                        ntxdave @Box
                        @Box
                        Here is my skp file: Box Practice 1.skp
                        • BoxB
                          Box @ntxdave
                          @ntxdave
                          I can't answer just now. I will tomorrow if I have time.
                          But lets clean things up a bit, rather than having this discussion in Tuna's Gallery thread.
                          Can you start a new thread in the Newbie sub forum and include your model. It would be best if you can include it with the setup before you used follow me.
                          Then Dave or Rich will split the relevant post out of this one and into the new one.
                          • ntxdaveN
                            ntxdave @Rich O Brien
                            @Rich-O-Brien said in I’ve Been “Boxed”:
                            let me know by tagging me in that new thread and I'll move this sidebar.
                            Not sure what you mean by tagging you.
                            Here is the new thread I have created: Box Exercise Discussions
                            • ntxdaveN ntxdave referenced this topic on
                              I see a major issue is that your profile is offset inward from the path but more than the radius of the arcs at the ends.
                              Do you really want the "knobs" at the ends to have that corner.
                              Here the profile (shown selected) is aligned with the path. On the right you can see some of the resulting extrusion. Might be better to put the profile outside the path.
                              • ntxdaveN
                                ntxdave @Box
                                @Box said in Box Exercise Discussions:
                                Box, I have tried many times now and I cannot get a smooth arch/connection between the two circles and therefore I am not getting a good outline for creating the model. Are there any tips you can give me for creating a connecting arch that will give me a smooth outline for creating the object in your example?
                                @Dave-R I did make the adjustments you suggested and I did a better result but I am having problems based on what I have asked @Box about.
                                As I have said before, I have used SU for several years now but for a very concentrated set of models and now I am trying to expand my skills and am not making very good progress.
                                • BoxB
                                  My guess would be your circles are not drawn on axis. Not at a computer so can't check your model.
                                  • ntxdaveN
                                    ntxdave @Box
                                    I thought they were. I will try agin, tomorrow I hope. 😁
                                    • BoxB
                                      It's pretty clear just from Dave's screenshot that your circles are off axis.
                                      • ntxdaveN
                                        ntxdave
                                        I used the green axis But I will try the red axis and see if it makes a difference. I will also make sure that when I draw the circle again that I follow the axis when drawing the circle. As I am typing this response, that is probably what I did wrong. Don’t give up on me. ☺️
                                        • ntxdaveN
                                          ntxdave
                                          OK, I made sure I drew the circle on an axis (red) and then I created the arch (see image below). However, once again things are correct. If you look at the image, you will see a gap and the points where the arcs connect to the circle are not properly aligned. I do not understand what I am doing wrong.
                                          • ntxdaveN
                                            ntxdave
                                            Well, I finally got things working. It took a little cleanup along the way but here is the results.
                                            Now off to some other bot Box's tips.................
                                            • 1 / 3
