    [Plugin] MultiTags for Sketchup
    extensions
    23 Posts 11 Posters 5.3k Views 11 Watching
    • F
      ferol
      Hallo, I tried your plugin, but I get white empty dialog box.
      Windows 10 + Sketchup version 2021.0.339
      And in Sketchup 2020 dont get nothing dialog box. After restart I get thisr errors:
      Error: #<NoMethodError: undefined method each_folder' for #<Sketchup::Layers:0x0000021a38918260>> (eval):758:in GetLayerListEx'
      (eval):764:in GetLayerList' (eval):333:in refresh'
      (eval):219:in initialize' (eval):1341:in new'
      (eval):1341:in initialize' c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:69:in new'
      c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:69:in main' c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:85:in class:Plugin'
      c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:6:in <module:MultiTagPlugin>' c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:5:in module:ZZLab'
      c:/users/fero/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/zzlab_multitagplugin/plugin.rbe:4:in <main>' C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in eval'
      C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in load'
      C:/Users/fero/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ZZLab_MultiTagPlugin.rb:26:in register_extension' C:/Users/fero/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ZZLab_MultiTagPlugin.rb:26:in module:ZZLab'
      C:/Users/fero/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/ZZLab_MultiTagPlugin.rb:5:in `<top (required)>'
        Layers folders were introduced into SketchUp and the API in v2021, so trying to use this extension in v2020 won't work !
        The author could include a Sketchup version check as the code loads, to tell you it's not compatible with your older version...
        It's quite straightforward to do and a kinder way of coding...
        • ezyuzinE
          ezyuzin Extension Creator
          release 1.1.230903:
          • added command to menu for reload visibility state,
            which can be broken in some cases (for sample: component reloaded from file)
          • automatic updating of the visibility on all scenes when their visibility changes
          • fix updating of the visibility on the Scenes: the status of object hiding changed to set via Hidden.
            Also stop use technical tag “Multitag Hidden” which was used to hide objects in earlier releases.
          [anchor= goto=https://zzlab-xs.com/downloads/MultiTag-1.1.230903.rbz:3m0vt35m]Download MultiTag-1.1.230903.rbz[/anchor:3m0vt35m]
          • ezyuzinE
            release 1.1.240531:
            • compability with sketchup 2024
            Download from Plugin Store
              jrbyors
              How do you purchase a license for the multitag extention? I went to the website and then checked out but would not let me pay with credit card.
              • ezyuzinE
                SUPPORT AND DEVELOPMENT OF THE PLUGIN HAS BEEN DISCONTINUED.
                Dan RathbunD 1 Reply Last reply
                • Dan RathbunD
                  Dan Rathbun @ezyuzin
                  @ezyuzin Any reasons why?
                  I'm not here much anymore.
                  ezyuzinE 1 Reply Last reply
                  • ezyuzinE
                    ezyuzin Extension Creator @Dan Rathbun
                    @Dan-Rathbun
                    The reason is: low demand for the solution (statistics of trial installations and downloads for 2 years), and as a result, low sales.
                    Now it is time to pay for renew license for Sketchup, hosting, certificates, and a domain name for the licensing services, but no any interest for continue, also have difficulties with payments for this services (EU/US sanstions + banned from Trimble).
                    Low demand for the solution >> no interest to find ways to solve problems with payments.
                    • B
                      Bratthaus
                      @ezyuzin I know this may be redundant, but is there still a way to buy this plugin even tho you no longer support it?
                      ezyuzinE F 2 Replies Last reply
                      • ezyuzinE
                        ezyuzin Extension Creator @Bratthaus
                        @Bratthaus said in [Plugin] MultiTags for Sketchup:
                        Sorry, no way, all used infrastructure was deconstructed.
                        The source code is preserved and maybe someday a free version will be made, but now not have enough time to this.
                        P.S./ On the Trimble forum says that this feature is not needed in Sketchup and it is enough to use Outliner and put the object in several nested groups.
                        You can try use this free workaround way.
                        • F
                          FlorinAp @Bratthaus
                          @Bratthaus ConDoc Tool has similar functions, but is expensive…
                          • ezyuzinE
                            v1.1.260101
                            • license free version
                            This is the previous version, but now free and does not require a license.
                            1 Reply Last reply 👍
                            • B
                              Bratthaus
                              Thanks! Gave it a try but no go, ah well....much appreciated for the help however....
                              • C
                                cescmari
                                Installed last week and I began to enjoying it. Great extension! Very useful!
                                But since the last SketchUp update, the extension is not working. SU version 26.1.252. A message appears saying there are compatibility issues with this extension.
                                EDIT: In the 26.1.256 version works again!
                                1 Reply Last reply 🔥
                                Reply Quote 2
