    [Plugin] CopyAlongCurve 1.0.4 (28 February 2017)
    16 Posts 14 Posters 29.3k Views 14 Watching
    • Bob JamesB Offline
      Bob James
      Excellent extension. Very similar to sdmitch's "Component_String".
        Pherim
        This is great, thank you!
        • alvisA Offline
          alvis
          Thank you very much. Very accurate.
            pxorduna
            Hello Anton,
            I got this error message after install the plug in and open Scketchup up
            (I have ScketchUp Version 8.0.164846, Windows 7 64bits.)
            ( I don't see the Extension Option at Menu )
            Error Loading File C:/Program Files (x86)/Google/Google SketchUp
            8/Plugins/ams_CopyAlongCurve/main.rb
            undefined method new' for Length:ClassError Loading File ams_CopyAlongCurve.rb undefined method new' for Length:Class
              Anton_S
              Hello, Alejandro,
              It is fixed now. Thank you for the report.
              Regards,
              Anton
                mriedel
                Great plugin. Works as advertised. Flexible. Most importantly, I was able to start using it productively -- without reading any documentation -- within seconds of installing it.
                • sketchartist023S Offline
                  sketchartist023
                  Trying to use this and it isn't working for this particular curve. The curve was a hand made line that I used TIG's weld tool to make it a curve. Weird thing is, it worked on the other curve just fine. Any thoughts? The object is a group, solid too btw, 0 errors with FixtIt. The line is shown as a curve as it has been welded. I have tried both closed and open curves. TY if you can help πŸ˜„
                  https://i.postimg.cc/V6s8Lt98/error1.png
                  [/url]
                    Share the .skp file so we can see what you have set up exactly. I just made up something that looks similar and it worked fine for me.
                    What version of SketchUp are you using? Please complete your profile.
                      KropocLeckor
                      Marvelous. Just Marvelous and Easy to use.
                        Requisher
                        Its amazing plugin! THANK YOU. May I ask, it is possible to get plugin button to put in in toolbar? Or how I can do it myself?
                          Dave R @Requisher
                          @Requisher You could learn to do the Ruby coding and add a toolbar. Might be easier to just create a keyboard shortcut for it.
